Who's right and who's wrong?
cjdelphi
Oct 26, 2011
1,166
before looking at the screenshot...
does a BMS control/regulate current when cells are stacked in series?
kellys_eye
Jun 25, 2010
6,512
Without looking up a standard response...... I would take Battery MANAGEMENT System to mean anything between simple monitoring to full protection and control depending on how that system is offered up. I wouldn't expect BMS to mean a specific means of control.
Consider either approach - per your attachment - to be acceptable, no right or wrong.
cjdelphi
Oct 26, 2011
1,166
I disagree, I can't find a single bms that current limits, it only cuts it off it exceeds the max current rating
if a cell approaches fully charged, it switches off that cell, there's no mention of the bms taking care of the current limiter...
if it did, people wouldn't buy specific chargers you would hook up you 15v and off you go...
Martaine2005
May 12, 2015
5,314
Isn’t a charger and BMS completely different circuitry?
With charger limiting the total current and the BMS monitoring each cell (balancing).
When integrated they would indeed monitor, sense and current limit.
Martin
cjdelphi
Oct 26, 2011
1,166
but they don't limit current in the sense that a current limiter does, if over current occurs the fet go off, current isn't reduced same goes for charging it, you decide current draw just don't exceed the bms rating...
how else do I get decide to charge at 5amps or 10amps with my lifepo4 (with bms) battery... or up to 25ampers but if I exceed it, it does /not/ limit it to 25 amps, it gets turned off until the current drops again
Martaine2005
May 12, 2015
5,314
I agree.
I charge at 1A or whatever I choose with my bench PSU.
Martin
cjdelphi
Oct 26, 2011
1,166
The onus is on your to do that since you were the one initially disagreeing ;)
show Kelly's eye and myself the switch
a current limiter reduces the current
a switch switches it on and off
since it has no current regulation it's a switch ;)
kellys_eye
Jun 25, 2010
6,512
A fuse is a current limiter. Exceed the current and it cuts it off, true, but it IS a limiter.
When you say "a current limiter reduces the current" it actually does no such thing. It stops it rising past a certain level - there is no 'reduction' at all.
cjdelphi
Oct 26, 2011
1,166
a fuse is a switch as well, it's fully on or it's fully off, there's no current regulation
cjdelphi
Oct 26, 2011
1,166
poly fuses, thermistors, MOV etc.. do control the current and are current limited....
cjdelphi
Oct 26, 2011
1,166
if you are referring to a bms, consider it a switch, it doesn't reduce current it over current occurs, it switches off until you reduce the current...
you don't have current limited power supplies you have switch mode power supplies because it's either on or off, so unless there's resistance involved it's a switch
kellys_eye
Jun 25, 2010
6,512
You are conflating current limiting and current regulation - there is a distinct difference.
Arouse1973
Adam
Dec 18, 2013
5,178
Do we have to define if it is constant current or foldback limiting?
