Who's right and who's wrong?
Arouse1973
Adam
Dec 18, 2013
5,178
Hello darling :) You remember lol. I thought I would jump in again on a lite note. I got fed up a bit with some of the posts and then COVID hit. Will pop in now and then
Martaine2005
May 12, 2015
5,315
Covid? You tart. You don’t need a mask for a forum!..
Of course I didn’t forget, sent an Easter egg to your work.
Martin
dave9
Mar 5, 2017
1,191
Semantics. BMS often limit current to the extent that there is a variable upper limit, for example when a temperature sensor reaches its set point, to prevent overheating.
Switching off the cell is implied to be current limiting because it is usually excess current ( multiplied by duration, and offset by ambient temp) causing the temperature rise.
dave9
Mar 5, 2017
1,191
You guys aren't wearing a mask?! I'm staying 6 feet away from my monitor from now on.
cjdelphi
Oct 26, 2011
1,166
switching off the cell is implied?
the word "switch" is mentioned in your first word, and switches have 2 states, on or off
there is no current limiting...
dave9
Mar 5, 2017
1,191
You fail to accept that "limiting" can be binary. This is limiting you from seeing the other side of the argument. ;)
cjdelphi
Oct 26, 2011
1,166
I'm switched off, limiting can be binary?
correct I don't see how, do you have a lab bench power supply? if I set the current of an led at 300ma , if the foward voltage drops the psu will adjust or limit itself to 300ma where as a BMS would simply terminate the supply completely and the LED goes off (binary) a pause and then it comes back on again, if it's over current it goes off again
that's not limiting current, that's a switch
dave9
Mar 5, 2017
1,191
Maybe you cannot use a switch to limit current. I can, and so can BMS designers.
That's not our problem.
Again, semantics. You want to pretend that current limiting needs to mean "constant current", when it does not. Anyone with the ability to use a full vocabulary would use the word constant instead of limit, if that's what they meant instead.
If you want to be pedantic and accept that it's limiting current to zero, that is still the opposite of unlimited current.
Maybe you just need a different hobby?
I will concede that it doesn't fall within the neat and tidy vocabulary you want to use, but it also does not fall outside of the more general communication of purpose.
Binary or shades of gray? Your topic has no useful purpose. That's binary to me but should at least be shades of gray to you.
cjdelphi
Oct 26, 2011
1,166
why the hell would I want to try a different hobby when I've spent the last 20 years building power supplies and circuits ?
maybe pulse width modulation confuses you? as it's either on or off on a duty cycle
do you say it's a switch mode power supply like everyone else does or do you call them current limiting power supplies? maybe you need a different hobby?
