Why is electronics so complicated?
TheGlimmerMan
He's a junkyard dog. With corresponding mathematical abilities.
You tally in at zero. A number you have trouble grasping the meaning
of.
Stand and deliver, boy. If I were a junk yard dog, you'd be a dead,
gnawed on dumbfuck. Do some math on that, boy. If I were any of the
things you and your retarded Johnny Wrong crew have been calling me, you
would already be dead, because I DO know where you are, boy.
Since you are still around, I think the ID of my species is safe, as
well as my character.
You, on the other hand... just made the title of slug. Despite how
well you calculator works.
Chieftain of the Carpet Crawlers
Everybody loves you, Archie!
When you find someone in this group with that name, you can then go
find the bridge. No. Go find the bridge anyway, fuckhead.
JW
You, in order to leave a bad taste in your mouth, I would attach a 3
inch hose, and hydraulically force about twenty pounds of feces into you.
Where does the other end of the hose attach to, your head?
TheGlimmerMan
G > Everybody loves you, Archie!
Archie > When you find someone in this
Archie > group with that name, you can
Archie > then go find the bridge.  No.
Archie > Go find the bridge anyway, fuckhead.
You can use all 100 of your aliases
but you're still Archimedes' Lever!
You can act like a ditz all your life, but you will still be greegor,
the pussified retard.
(and Dimbulb, Nymnal the no nuts nymshifter,
AlwaysWrong, etc.)
Never had any of those as a nym, dumbfuck.
Clearly you have issues about your identity.
Clearly you have issues with reality and facts. You never state
anything that conforms to either.
Why is that?
Probably because you are a drug crazed fucking nedertarder.
TheGlimmerMan
Who or what told you that I live in the Netherlands, Archie?
In the first post I made where I referenced it, your hop trail went
through there.
Cedar Rapids is much closer. That was a cursory glance. I could do
far better, but I would have to lower myself 160 IQ points down to your
retarded, stalk boy, 20 IQ mentality.
TheGlimmerMan
I don't hide my name,
Yesm but you do hide your game. Quite poorly so, however. You are
transparent.
my location, my business, my products, my
education, or my schematics.
Bullshit. I'd bet that there are several schematics that you would not
make public. If not, you and your 'designs' are lame.
YOU gutlessly hide everything.
No. I hide ONLY my identity and do that for the most common sense
reasons. This is Usenet, idiot.
Stand and
deliver yourself!
Every time I do, retards like you, and the Thompson tard, and the
Terrell tard, and a couple lame stalkers accuse me of lying. The funny
thing is that you do it with zero knowledge and zero evidence.
Essentiallym you are all total fucking retards, that should receive
public stonings, at best.
Your character is "coward."
My character puts you and yours to shame. I am not on Usenet calling
folks liars with zero facts to make the claim with. You are so goddamned
stupid that you cannot even see the severe character flaw in you that
behavior represent.
But don't be upset, it's common enough.
In dipshits like you. Were I to come up there and challenge you to a
few rounds down at the local boxing ring, I'd bet you would cower
immediately. So, **** off, liar.
TheGlimmerMan
What's your real name, coward?
John
I am not at liberty to discuss my identity.
I am also not in any Mood to tell a sub-human fucktard like you such
info.
If it were not for your retarded behavior, you would garner other than
a sub-human rating, but since you insist on posting bullshit on a
constant basis, you get no quarter.
TheGlimmerMan
You are a sub-human fucktard that should be erased. Sad thing is that
the piggery is too goddamned retarded to know that killing a sub-human is
not a crime. It is a community benefit. Sadly though, they are nearly as
stupid as you are.
TheGlimmerMan
What, that they spread heat? ...if they are polished aluminum with e=1.3.
Heat spreaders are a conduction mass sink device, and surface quality
has nothing to do with it.
You bond it to the surface of the box, just as was stated, and then you
attach the source, just like you would attach your transistor or whatever
source to any other sinking device.
The ideal spreader is thick enough to spread the heat over the target
width or a width that is wide enough to make the external interface
efficient enough to sink the source OVER TIME. It is possible to make it
a small, pyramidal enlargement of the original heat source package
conduction tab/surface. There is a point at which you have overcome the
thin box wall issue and need no larger spreader.
On the OUTSIDE, however, you are in the realm of conduction cooling as
you need to sink that internal spreader footprint plus a slight bit
larger into a MASS that either leads to MORE mass, or an efficient fin
array or chiller source.
In reality, all sinks, regardless of type, be they convection cooled
finned devices or copper tubed modern jobs, are "conduction cooling
elements" from the POV of the heat source. THAT is the device that needs
to have it being bled off as fast as it is being created via dissipation.
SO the FIRST thing it needs is a mass of a determined size that has
fast conduction properties.
Then, the bleeder mechanism of choice weighs in. This is why many newer
sinks for CPUs have been a copper slug, press fitted into an Aluminum
finned array. I have also seen, and collected discarded solid copper
sinks.
So, if the finned sink likes the fast conduction slug interface to the
heat source AND the finned array, then the INSIDE of the box having a
good, fast conduction mass in it to make up for the issue the thin wall
would cause is the right way to conduct the heat to the outer sinking
mass, and subsequent bleeding (sinking) mechanism (fins, more mass, etc).
I have one here.
http://www.flickr.com/photos/nonlin/4773788504/in/pool-98328567@N00/
It is an inch and a quarter by an inch and an eight solid Copper slug,
surrounded by the best Aluminum fin array I have seen in a while.
The first AMD cpus that came out running very hot, and if the sink was
not intimately mated the CPU would fry and take out the whole MOBO with
it.
We all know you're dumber than a stump, DimBulb. You don't have to prove it
daily.
<no mood for AlwaysWrong's error's>
TheGlimmerMan
More word salad
and surface quality
Of course it does. Good heat transfer, from semiconductors on one side
and to the box on the other, needs flat surfaces.
John
The term refers to surface index, not flatness, idiot.
Note also that I made the requisite that the box be bonded to the
spreader by silver filled thermal epoxy. Flatness would also not be an
issue in such a case. Not that you could understand that fact.
Most if not all die cast boxes have a fairly poor flatness anyway, and
that is especially true about the internal surfaces. But I wouldn't
expect a retarded **** like you that spend his time deriding others
information by posting bullshit to have any grasp of that tid bit.
And finally, dumbfuck, his "polished aluminum" would degrade the
flatness as well. Of course I would not expect a twit like you to have
grasp of the difference between the flatness of a machined or precision
surface ground face, and one that was polished by a retard just like you
with an abrasive belt and hand pressure.
Then, there is that "polish" term. I call polished Aluminum a mirror
finish.
An idiot like you likely thinks that "polished" means what the dopes
down at the metal house send you after it goes through their "timesaver".
Yet another stupid post by the Larkin dumbfuck.
