Why is electronics so complicated?
TheGlimmerMan
What's a surface index?
Looks like Johnny Bright isn't so bright after all.
You previously spouted "word salad" in another post, but the salad is
in your brain. It is Dumb Boy Salad, and you specialize in it.
I knew what surface index was back in the early 70's at 10 years old.
Do you even know the difference between a #3 and a #8 polish?
I mean you already mistook surface quality for surface planarity, and
they are two entirely different animals.
TheGlimmerMan
Of course it would. Silver filled epoxy is still mostly epoxy, and
doesn't conduct heat very well. Even diamond filled epoxy doesn't
It certainly would conduct better between two "flat surfaces" that are
not as flat as an idiot like you thinks they are.
It is only for the fine gaps, idiot. Both faces are essentially flat,
better rarely ever to the degree they would need to be for a dopey ****
like you to even be able to see the miniscule difference. You know...
like OPTICAL quality flatness AND polish.
Another surface quality 'thing' you are unaware of. The main body of
the block would be directly interfaced, even if it was a mere, cheap
extrusion without surface finishing.
Even when one thinks one has two flat faces, one should *still* apply
gap filler media, even if it is only for fine scratches and gap
management.
If silver filled epoxy was so bad ALL the chip makers would be using
something else to attach their dies to the chip base with. They are not.
They ALL use silver filled epoxy, and nearly all use the same one I have
and use. EpoTek.
You are about as dumb as it gets. You would probably think that a
simple two screw attachment would perform better.
TheGlimmerMan
I posted that fact here some time back. Guess you missed it.
You missed a lot more than I ever have. Here and anywhere else in
life.
TheGlimmerMan
And you have a serious scat fetish.
John
The facts are the facts, John, and the fact of the day is that the CRAP
that John Larkin posts in sed is 100% horseshit, and you are full of your
own as well. Take your stinking ass elsewhere.
Jamie
No, I don't know many that had to spit and shine shoes when
they were growing up.
You obviously are an expert!
Jamie.
TheGlimmerMan
They use silver epoxy because it's electrically conductive.
John
No, Johnny. They use it because it conducts HEAT as WELL AS being
electrically conductive. The device they bond it to is where the user
places the heat sink. Simple physics, boy.
D'oh!
I
I AM THAT I AM
Repost your stated purpose (manifesto) from a year ago.
Greegor is too fucking stupid to actually know the true definitions of
several hundred terms, I am quite sure. Much less comprehend them. He
is so far off the mark that the terms contorted and convoluted come to
mind.
TheGlimmerMan
Right and wrong is a much stricter standard
in this case than legal/illegal, by the way.
Just like 'smart and dumb' as it relates to you, eh.
You fit the "dumb" moniker to a tee.
TheGlimmerMan
dysfunctional
YOU authoring these retarded "here's Johnny" posts are as stupid as it
gets. You have ZERO qualifications, and it shows, asswipe.
That last several paragraphs of total and utter horseshit proves that
fact beyond doubt.
YOU are the dysfunctional little bastard on this bus, boy.
TheGlimmerMan
Even with proxies, the original physical location of the message can
be traced.
You give the retarded stalk boy twit too much credit.
He is too goddamned retarded to actually know how a modern network,
much less a modern protocol works.
TheGlimmerMan
Jamie.
Polish numbers are for metal polishing, like that found on stainless
steel, you retarded ****. It has nothing to do with shoes.
Thanks for proving to the world yet again that you are nothing more
than a retarded little twit.
TheGlimmerMan
Silver is expensive.
More proof that you do not even know what the numbers they use are.
**** off, dumbass. Then die.... please.
TheGlimmerMan
doesn't make all that much difference.
If the fill particles increase the gap, they can actually make theta
*worse*.
With "can" being the key word. There are also instances where
dissipation capacity doubled. In other words, you 're an idiot.
Just this month, in fact, I read an article about it in a very
respectable publication.
TheGlimmerMan
It has to do with numbers. You wouldn't understand.
You, the expert with numbers, *derive* this claim of a fact from what?
BTW... watch out on this one. You are going to lose. Already did, in
fact. The numbers are in my favor. Every other week, in fact.
TheGlimmerMan
GX > Even with proxies, the original physical location
GX > of the message can be traced.
Archie > You give the retarded stalk boy twit too much credit.
Archie > He is too goddamned retarded to actually know
Archie > how a modern network, much less a modern
Archie > protocol works.
Green Xenon and Archie express the
identical falsehood about routing from a proxy.
http://www.google.com/#q=proxy+server
Not from an original cox.net hooks, dumbfuck.
My IP would appear completely different, DUMBFUCK!
You cannot proxy out through cox, and then back through cox, you dumb
Every time you speak, you show us how retarded you are. You posted a
link, but that only further proves how little you know about it.
