why no corona discharge from power lines?
jamm
Something i've never puzzled out..
If I make a 14kv generator (and I have made a few high voltage generators in
my time), I get constant corona from its unattached output.
Why do the 14kv power lines strung around town not do the same? I know
sometimes there is just a little bit of discharge around power lines, i've
seen and heard it. But thats not what i'm talking about.
Is it because the lines are fully terminated into a load?
*From the 1966 TV series:*
Robin: You can't get away from Batman that easy!
Batman: Easily.
Robin: Easily.
Batman: Good grammar is essential, Robin.
Bob Eld
No, It has nothing to do with the load. It has to do with the electric field
intensity. The field lines converge into conductor. The smaller the radius
of that conductor, the higher the field strength is, because of this
convergence. The lines get closer and closer together as they converge.
Depending on air pressure, humidity and other factors break down of the air
causing corona happens at a field strength of about a million volts per
meter. That number is easily exceeded with small diameter wires or point
sources whereas the power lines are much larger in diameter and never
terminate in points that could cause such breakdown. Your bench top supplies
have small wires with sharp ends that create the high field intensities.
Note that very high voltage lines are always multiple conductors spaced a
number inches apart for this very reason. It keeps the converging and
increasing electric field in check within allowable limits around such
lines. There are equations to determine the expected field intensity around
a given conductor.
jamm
Thanks for the replies all. That makes sense.
Batman: Easily.
Robin: Easily.
