Hi
I have made a power supply, the schematic is below.
as you can see, i have put a surge resistor (R1 = 3.3ohm, 2watt). as You know this
resistor controls the current at circuit start up. because all the caps act like short circuit at circuit
start up, it protects diode bridge from high current.
but he problem with my circuit is that, the output votlage decreases when connected to load.
you may say because the current passing R1, increases the voltage of "C" point and causes voltage
decreases in "A" point. but my theory is, the output voltage of LM317 proportion to its ground is always
constant, so if the voltage of "C" point increases beacuse of load current, so LM317 should increase its output
to keep the voltage constant, BUT WHY THIS WOULD NEVER HAPPEN.
I hope u understand what I meant.
here another short circuit protected application from LM317 Datasheet. so output voltage in this application should decrease
like my circuit.
ThanX in advance
Shahriar
like my circuit.
ThanX in advance
Shahriar
