Widget for joining 3-core mains flex
Coleman
If the flex goes round a indoor doorpost and I pull the flex then I
am not putting much strain on it at all.
Then you are dangerous beyond belief. You cannot do this - it
violates UK regulations.
You must add a socket and a plug to connect the two cables.
I will have to live in sin then! :)
Any other joining method will result in potential loss of fire
insurance and possible prosecution.
Why do you need such a long cable?
The cable on my fan heater is about 4 to 5 foot and is too short to
be used whre I want it to be.
I want it to extend it to about 10 foot.
Coleman
In the UK portable equipment has to be provided with a fitted plug
- in recognition of the fact that many people were incapable of
correctly fitting (and fusing) one themselves.
So, what are the chances that one of those will correctly choose
and wire one of the above? Or use a non-rugged one outdoors, drag
it around corners, let it fall into a bucket of water, etc?
Many (most?) do not have anything to limit the bending radius of
the cables at the point of entry close to the fixed cord grip. So
strands of the cores break, leading to the risk of fire, failure,
etc.
Few are vapour-tight or even water-tight. As the are often dragged
around through damp grass, left in the shed, etc - there is a real
risk of corrosion..
Bear in mind that a typical application is to "repair" an electric
garden tool - where the user has cut the cable...
Replacing the two cables with a single, contiguous, one is by far
the best solution.
It is the best but sometimes it is too long a job to open up the
appliance and to attach the new flex cores because of the way user-
unfriendly way in which the appliance has been designed.
Coleman
I also thought it was pretty obvious what also applied to soldered
joints. Solder is weak stuff too, though I've not seen any
significant failures from soldering pretwisted flex (at LV). But
not everyone twists enough before soldering.
ISTR there was a time when the different twists had their own names.
Maybe they still do.
Wasn't something like "Western Roll" one such name???
Jamie
Hey, are you related to the Coleman company? :) I just bought
a 21 volt cordless drill from Coleman.?
P.S.
Can some one tell me what a flex is?
Michael A. Terrell
Coleman is an old AMERICAN company that made gasoline lanterns and
camping gear. Good luck with that drill. I was given several new 18 and
19.2 volt Coleman Powermate drills, along with eight batteries. The
piece of crap doesn't have enough torque to do much, and one snapped the
steel shank that connects the chuck to the gearbox. The other was
shipped without a wire from the PWM board, to one side of the trigger.
I fixed it, and made one complete set out of the pile of parts. I
couldn't even give it away. A $9 drill from Harbor Freight works a
WHOLE lot better.
P.S.
Are you really that dense? It is a British term for flexible line
cords. It has been discussed countless times on the electronics and
electrical engineering newsgroups.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Jamie
WHOLE lot better.
well, I'm not British and I have never heard of the term "FLEX"..
Here we have different names, maybe not the correct name but different
never the less.
SJO, Rubber cord, zip cord, curly cord and yes FLexible cord I can
comprehend, but when using the terms "FLEX" with out cord or what ever
afterwards kind of throws me. For all I know you could have been talking
about "GreenField", BX, BC, Seal Tight, what ever....
H
Homer J Simpson
Then a regular extension cord will work fine.
Palindrome
Huge said:
Methinks you worry overmuch. I've been doing this for years, although
it's solder, adhesive heatshrink (don't forget to put it on *before*
soldering the joint), more adhesive heatshrink over the whole thing
then insulating tape. OK, it isn't that bendy or pretty, but it'll
go on a drum and I've never, ever, had a joint fail, and there's one in
the lead for my big mains drill.
I did write "normal" - which you too seem to think is inadequate, as you
use adhesive heatshrink.
Whether it will go on the drum neatly depends on the size of the cable
and the drum.
I've used similar techniques to the one you mention where cable
replacement was impractical, eg re-joining the command and power cable
of a tethered submersible. That has been good enough to survive a few
weeks of fairly deep salt water immersion, etc. But the repair only ever
lasted a few weeks, no matter how carefully it was done. The cable alarm
would inevitably sound and the fault was inevitably at the join.. So no
way was it as good as the original cable, unjoined.
Andrew Gabriel
My recently purchased Bosch trimmer, although it had the inconvenient
"needs 2 hands" feature (the reason God created gaffer tape) did not
have a plug/socket, making it inconvenient to store. I fitted one.
I don't know if the safety break was a regulatory requirement,
although it was pretty universal. Does your Bosch have active
breaking (stops dead when you release the handle)? I guess that
would do the same thing, although the active breaking on two
lawnmowers I have both stopped working after a couple of years,
and now the blades just spin down under their own momentum when
the trigger is released.
Coleman
although it's solder, adhesive heatshrink (don't forget to put it
on *before* soldering the joint), more adhesive heatshrink over the
whole thing then insulating tape. OK, it isn't that bendy or
pretty, but it'll go on a drum and I've never, ever, had a joint
fail, and there's one in the lead for my big mains drill.
I have been doing it for years too (without the heatshrink).
I am genuinely quite surprised that there are so many posts worrying
quite deeply about safety.
Of course what I want to do is less good than having a single piece of
flex. But this is not exactly HIGH risk in the circumstances I want to
use it the appliances in.
Eeyore
Andrew said:
Does your Bosch have active breaking (stops dead when you release the handle)?
That would be active braking.
break =/= brake
Graham
Palindrome
Eeyore said:
break =/= brake
Judging from his words, in Andrew's case it does appear that the brake
had been actively breaking...
O
Owain
Coleman said:
Yes it will but it s clumsy and inconvenient to get out each time!
Then stop bodging things and install a proper, permanent socket where it
is needed.
Owain
Lurch
Make the join at the end near to the appliance so it's not dragged
around corners all the time.
H
Homer J Simpson
Jesus Christ, do you drive? You're about 300 times more likely to
die in a car crash. Get a grip.
You are a dickhead. What part of "I'm sorry sir. Due to your haphazard
electrical 'repairs' your insurance does not cover the total loss of your
home" did you fail to understand?
Dave Plowman (News)
your home" did you fail to understand?
Can you give some examples of this in the UK? It would be very difficult
to prove in a court of law.
H
Huge
Yes.
Andrew Gabriel
Not sure that's relevant -- I've never seen a [UK] policy which
excludes this anyway. Actually, policies often explicitly include
cover for DIY accidents.
