Wifi controller for a linear actuator
br7332
Oct 14, 2022
I am trying to figure out how to wire a smart controller I found to a linear actuator to open a door to my doggie door. The actuator only has 2 leads and is controlled by simply reversing the polarity but the wiring diagram for the controller I found shows an actuator with 4 leads. I am not using a physical switch. They may just be incompatible. Would anyone have any thoughts or suggestions for wiring or on different smart controller?
14,317
The controller is made for AC mains operated motors, 2 per "curtain". It activates either the AC output ("L") for "up" or for "down" to control a curtain.
Your actuator is meant to be used with 12 V (DC) and, as you observed, direction is controlled by the polarity of the voltage.
These two are completely incompatible. You will need a controller that issues 12 V (DC) with the correct polarity for controlling the motion of the actuator.
br7332
Oct 14, 2022
Thank you! That makes complete sense. Don't know why that didn't dawn on me. Already found a DC controller on ebay. Thanks again!
