Will covering ring on male TRS jack with tape work?
Ronx
Jul 30, 2019
10
I plan to connect balanced TRS output with unbalanced TS input and I wonder if instead of cutting the cable and leaving ring floating I could just cover the male jack itself (the ring part that goes to the unbalanced input) with insulation tape. My guess is it should prevent the signal from the ring connect with the sleeve of the unbalanced, TS input.
14,487
no, the tape will just get pushed off when the plug is inserted in the socket then it will block up the socket
Audioguru
Sep 24, 2016
3,656
Simply do not connect your unbalanced circuit to the ring terminal of the jack. The tip will be the live signal and the sleeve will be ground.
Ronx
Jul 30, 2019
10
Thanks for the reply. How do I do that? The only thing that I can think of is cutting cables, connecting TRS Tip with TS tip, TRS sleeve with TS sleeve and leaving TRS ring floating. What's your solution?
Audioguru
Sep 24, 2016
3,656
You have a balanced TRS "stereo" plug and you have a balanced TRS jack instead of a unbalanced TS "mono" jack. Simply connect the T live wire and the S ground wire to the jack with its R terminal not connected to anything.
hexreader
Apr 21, 2011
139
I have devices (Behringer 9024, DSP1400P) that require that the "ring" output (and inputs) be grounded for single ended output, otherwise massive noise and distortion are introduced. I sense that the solution balanced to single-ended depends on the devices to be connected.
See discussion here:
https://www.soundonsound.com/forum/viewtopic.php?f=15&t=57712
Audioguru
Sep 24, 2016
3,656
The "ring" output on a balanced connector is a signal that might cause damage if grounded. Connecting the T as a signal and the S as the cable shield and ground wire should work fine with a -6dB signal loss.
hexreader
Apr 21, 2011
139
.... unless you own the (admittedly old) devices that I mentioned ...
Did you read the discussions from my link?
"Should work fine" is not the same as "does work fine"
... or maybe I mis-understand my own experiences ...
Maybe the answer is to try open circuit ring, then if you hear excessive noise, try short circuiting the ring? Or maybe (not tried it) resistor rather than short would satisfy all equipment? I will be interested to hear of any simple solution that is optimal for all equipment of all ages that suits all circumstances.
Interesting topic though....
Audioguru
Sep 24, 2016
3,656
I did not finish reading the other thread.
Half of a balanced output T and S (where the S is the cable shield) is the same as an unbalanced shielded signal. If you get a ground loop and its noises then you should use balanced to balanced.
Martaine2005
May 12, 2015
5,318
I agree with @hexreader . It totally depends on the equipment.
Some equipment have circuitry to adjust the signal depending on it’s input signal. Some attenuate while others amplify. Some have a simple switch. Some TRS to TS converters have impedence matching.
However, The OP is going from an audio interfase to a guitar pedal.
Balanced to unbalanced. TRS to TS will GND the ring. Now again, depending on the circuitry of OPs equipment, it will likely have one of four outcomes.
1. Wont work at all
2. Has signal loss (-6db) there about.
3. Has distortion (possibly line level)
4. Ground loop hum
All the above are easily rectified but YOU need to DO it first and post your results, if any. It might work absolutely fine with no problems.
As @Tha fios agaibh always says “suck it and see”
Martin
hexreader
Apr 21, 2011
139
Agreed - balanced to balanced is the obvious professional solution.
But I sense that you have missed my point. Half of balanced signal is not always the same as unbalanced at half amplitude. Picture an output that consists of transformer secondary that is isolated from shield. Connecting only one side of the secondary winding will not give any meaningful signal.
Not sure if my equipment has a transformer at the output, but it seems to behave as if it does. Shorting the ring to shield solves my balanced to unbalanced issues admirably, but according to the forum I linked to, it can cause damage to some equipment.
Edit: After checking Behringer 9024 manual, I see that it instructs that one leg (ring) be connected with shield when using unbalanced output (30 Ohm) over balanced output (60 Ohm). The impedance difference suggests to me that the output is not as simple as just a transformer. Don't understand.... I only know that open circuit ring does not work, while shorted ring does
Martaine2005
May 12, 2015
5,318
Shorted ring works because some inputs (old) have a larger shield connection thus shorting the ring. Newer or typically available equipment have a smaller shield connection avoiding the ring. Others have deliberately shorted the ring for this purpose. It’s not rocket science. Other than that, the impedence will be determined by the device. Then impedence matching may be employed to use a suitable output level.
Your old equipment is newer than mine. I have balanced to unbalanced . Some equipment needs isolation, others need ground hum. GND reference . If both devices use the same GND, it can have terrible ground loop.
Ronx
Jul 30, 2019
10
1. Wont work at all
4. Ground loop hum
Martin
I'll leave ring floating and see how it goes. I was also checking out this site on audio connections: rane.com/note110.html
And from what I can see my case would be 9b, TRS to TS. The diagram says to leave ring floating. I hope it will work.
11 figure looks similar but I don't know what cross coupled output is. I'm connecting tascam us2x2 (line out) with Behringer super fuzz pedal.
Audioguru
Sep 24, 2016
3,656
I was thinking about a balanced output done with opamps that are not isolated from the shield ground like a transformer would be.
