Win Enterprises PL-10000-0 (computer) need power supply
Yeah Boi
Mar 24, 2018
52
Hi everyone ! I need either to find the power supply for the unit or (I guess THIS will be the viable option) to make one from one that's compatible.
But I have two issues with that. Here is the machine:
The biggest issue is the pin layout. I've never seen it before. I hope we don't need pictures from below the PCB because I don't know how to remove the front cover yet.
The second issue is that I do not understand what I need. The link below is the only information page I found of it, and the power supply values are there, but what do they mean ? What I understand is : Input +5Vdc@6A Output +12Vdc@200mA OR -12Vdc@120mA
https://www.win-ent.com/Platform/pl-10000
I wrote to Win Enterprises to know if they have any picture o the power supply or additional information, but I sure doubt any answer.
Thank you very much.
Martaine2005
May 12, 2015
5,318
The power supply has +5V, +12V and - (negative) 12V.
The current in Amps and mA is what the unit requires. Having more current available is fine as the unit will only draw what it requires.
Eg. +5V @10A.
You will certainly need to access the underside of the pcb at some point to find out which pin is what.
Martin
Martaine2005
May 12, 2015
5,318
I couldn’t edit my post on my phone.
An old tower PC ATX power supply would be more than adequate for you to repurpose. You need to find out the pin voltages though.
Martin
