Win, where do they all come from ? (e-)
F
Fred Bartoli
After some struggling with other details, I finally come back to the input
sampling gate of my low noise preamplifier.
So I need a low R, *low* Qinj, low leakage switch in a high impedance (Gohm)
chain.
Got samples of that supposedly nice ADG444: 35/40R typ @ +/-15V under 1pC
around 0V CM. Just what I want.
Well, I need well below 1pC, but trimming one of the supplies will allow
precise nulling of Qinj.
Time to breadboard...
D _/ S |\
.--o/ o-----+-----+---------|+\
GND .-. | | |/ |
100M | | --- 1nF '------'
GND GND
All is good:
- leakage under 2pA,
- untrimmed Qinj = 1.5pC
- easy trimming down to the fC level
- trimming sensitivity about 1fC/mV (of +supply)
Good, that will nicely do...
.... but, all of a sudden I had some doubts. Well, just wanted to make sure,
because I had been burned in a similar case before with 4053 switches.
So I sligthly modified the configuration:
D _/ S |\
.--o/ o--+--+-----+---------|+\
GND GND
233pC.
Arghhh.... a 64Hz switching frequency will saturate my DC servo loop.
Goodbye ADG444.
see www.fbartoli.com/pub/sed/ADG444_test_summary.pdf
I guess other AD low charge switches exhibit the same behavior.
BTW Win, at least for Onsemi it seems that the 405x have a T arrangement.
OK, the central leg is not strictly grounded (connected to VEE). See:
http://www.onsemi.com/pub/Collateral/MC14051B-D.PDF#page=5
W
Winfield Hill
Fred said:
So I slightly modified the configuration:
D _/ S |\
GND GND
233pC. Arghhh....
You weren't feeding the CMOS switch from a low-impedance source?
Oh, that's too bad... :)
F
Fred Bartoli
Well in the real situation I am, but not at DC:
___ ___
GND -|___|-+-|___|-.
10u '--|-\ |
_/ | >-+------
.--||----o/ o--+------+--|+/ |
| | Zg=1R 1G | | ---1n |
| | +300nH | | | .-.
| | GND | |
GND | |
| /+|-------- GND
| || ___ |
'---||--|___|--'
But there I have a track-hold-track sequence and I need consistency down to
a few tens on nV between the 2 track phases.
233pC is 23uV across the input DC blocking cap after each hold step.
Fortunatly I still can go the all discrete way, which I'd prefer have
avoided, but this doesn't explain where do all those e- come from.
W
Winfield Hill
Fred Bartoli wrote...
Yes, only that's quite different from the cmos T-switch scheme
used to improve high-frequency attenuation.
CMOS switches are made from paralleled N-channel and P-channel
parts, with the gates driven by direct and inverted full-supply-
swing logic signals. In early parts such as the cd4016, the two
MOSFET switch substrates were tied to their opposite supply rails.
For signals near each rail one of the two FETs would have very
low resistance, thanks to its high Vgs voltage. But for signal
voltages midway between the supply rails, each MOSFET had half
the Vgs it formerly enjoyed, and the switch's Ron would peak at
an undesirably high value.
In the late 60s RCA invented an improved circuit and fielded it
in the 4066 replacement for the 4016. Their scheme was to switch
the substrate voltage of the N-channel part away from -Vss, where
it was tied during switch-OFF, and connect it to one of the input
signals during switch-ON. The result was a dramatic reduction in
Ron for signals in the mid-supply region, as can be seen in the
three-region Ron curves. The technique of switching the substrate
from Vss to the signal line and back has been used in virtually all
cmos switch ICs designed and marketed since 1970, including the
Motorola / ON Semi mc14051B. One feature I notice in the ON Semi
schematic is that during switch-ON they tie the N-channel substrate
to both inputs rather than just one, using two small cmos switches.
The problem with this substrate-switching trick, as you have very
painfully observed, is the cmos switch that switches the substrate
may have a short ON overlap time with the N-channel FET to Vss,
which allows the circuit to grab a little bit of "dc" current from
the signal pins at each switching time. Although most applications
are not affected, some are. We old-time CMOS users first observed
this issue shortly after the cd4066 and cd4053 were released in the
late 60s. We discuss this in AoE, trying to give you a head's up.
You can still obtain cmos switches that don't use the substrate
trick, such as the LTC1043. Notice the single peak in the 1043's
Ron-vs-Vin plots. Perhaps using one of these will make you happy.
Joerg
Hello Fred,
Win has explained it quite clear. The switch I used often was the SD5400
but since this is just a quad of single FETs it requires hooking up
another quarter of it "in reverse" to counter the charge injection with
one of opposite level.
For really low injection I have used diode arrays driven by tiny toroid
coupling transformers. I didn't do the math for your case but one app
was the sampling of a CCD array. Sampling duration was around 15nsec
with the sample pulse having rise and fall times of a few nsec,
intervals were around 70nsec and we had to read down to -60dB from full
scale (half a volt or so) without even a whiff of charge injection. Lo
and behold it worked right away, Ci was so low I couldn't even measure
it. But the diodes have to be at least paired if you can't find a decent
quad. IIRC I placed some foil between primary and secondary and grounded
that to avoid any capacitive coupling. And yes, you'd have to make
your own transformer. I found none of the SMT commercial ones to be
suitable but didn't spend too much time since winding them was easy.
Regards, Joerg
Q
qrk
chain.
D _/ S |\
GND .-. | | |/ |
GND GND
All is good:
D _/ S |\
GND GND
233pC.
Goodbye ADG444.
Fairchild FSA66 is an interesting part. They claim 0.05pC charge
injection. Don't know if that's real or a typo. Mouser carries this
part. I'll be trying this part out in a month or so.
F
Fred Bartoli
Thanks Mark. Don't know if it's a typo either but I've ordered samples, so
we'll know soon.
The 0-5V supply will not make my life easier, but I can make an effort if
it's spot on on all the other characteristics.
F
Fred Bartoli
Joerg said:
Hello Fred,
Unfortunately I don't need short sampling time, but short _blocking_ time,
and almost DC response otherwise, so a transformer driving isn't possible.
Two balanced current isn't possible either due to the node high Z (1G) and
sensitivity to current noise (which triggered the 1G biasing impedance).
Plus I'm dubious about the bridge V drop stability down to 10-20nV (that's
only 10^-5K temperature matching across the bridge :) under the sampling
transients.
I tried the easy path, but I think I won't avoid the SD5000.
W
Winfield Hill
Joerg wrote...
Hello Fred,
SD5400 but since this is just a quad of single FETs it requires
hooking up another quarter of it "in reverse" to counter the charge
injection with one of opposite level.
That's an interesting trick.
W
Winfield Hill
qrk wrote...
so we'll know soon.
if it's spot on on all the other characteristics.
Fred, did you read my detailed posting? I imagine the FSA66 will
have the same problem, but they don't show an Ron-vs-Vsig plot so
we can't predict in advance. Remember I had suggested an LTC1043,
you should try that part and report back to us. :)
Jim Thompson
Joerg wrote...
Commonly done for you in "better" switches, like the ones I design
into my chips ;-)
(Dummy switches with the opposite phase drive.)
...Jim Thompson
I
Ian
"Fred Bartoli"
transients.
Have you looked at the Peregrine Semi quad FETs? I've not used them, but
I believe they might be interesting for this sort of application.
http://www.peregrine-semi.com/
Regards
Ian
Joerg
Hello Fred,
The other way around would be fine but in your case the transformer
thing probably ain't the thing to do.
transients.
Tough, even with a quad.
But be prepared for sticker shock ;-)
Regards, Joerg
F
Fred Bartoli
Thanks Win.
Now that you've refreshed my memory, I remember having read that story about
the 4016/4066 many many moons ago, but where was it?...
One thing I didn't catch then, apart from the Ron benefits, is the
consequences of that body switching. And I probably skimmed through this AoE
passage a bit too fast, too :-( But now the Ron curve shape won't go
unnoticed any more :))
Thanks for reminding me the LTC1043. I've wrongly classified it along those
(to me) desperating low Qinj switches, discarded it as its single supply
isn't best suited for my needs and then simply forgot it.
I've now some on order for test, but the RDSon is a bit high to my taste:
with about 100R RDSon I'll already need about 10000 averages to bring the
signal reasonably accurately out of noise, which I had hard time to make the
test bench guys swallow.
With about 130R Ron at the Q sweet spot the 1043 is quite close, but
depending on the signal feed through I may have to have 2 switches in
series(with a 100/220p bypass cap in between). But that'll make for a 25000
averaging. <cough> Maybe I can parallel 2 switches.
But the SD5000 at 30R @ 10V totalizing 60R is much more appealing.
I'll check them both.
Thanks again.
F
Fred Bartoli
Yes Win, I've read it and began replying when interrupted. Thanks.
I now well understand all this but the rising RDSon figures gave me a slight
hope, so I did, just in case, with other parts.
OTOH the specific measurement conditions may hide a lot of thing but they
also have a range of NMOS only bus switches so I just considered the case
open with this part. Probably 1 chance out of 1000 to be lucky.
I've also the LTC1043 on order, but the RDSon is a bit high to my taste and
the SD5000 is better in this respect. (see details in the other reply).
Joerg
Hello Fred,
Since you mentioned that techs do the assembly, one word of caution: The
SD5000 or in my case SD5400 is the most ESD-sensitive device I have ever
met. The tech blew them on 1st, 2nd and 3rd attempt. After the 3rd he
became quite mad and was absolutely certain my circuit was wrong and
blowing the devices. So I made sure he grounded the circuit board,
himself, the iron, the mat and left the feet off the linoleum while
handling the chips. Bingo, worked every single time.
Regards, Joerg
F
Fred Bartoli
Joerg said:
Hello Fred,
Sure, but I'm not Win (yet :) ) and have no tech. So as I'll know who to
blame, I'll try to do it well first time.
F
Fred Bartoli
"Fred Bartoli"
I've received the LT1043 and also the latest AD low Q parts (ADG121x) which
AD recommended after some interesting exchange.
I must say I tried them, but without much hope. And indeed... they work
amazingly well. Absolutely nothing common with the ADG44x.
The high impedance test circuit was, as before with the ADG444:
D _/ S |\
GND GND
For the part I tested, the net injected charge is 0.12fC after a full
ON/OFF/ON cycle.
This represents a negligeable 12pV on my 10uF input cap. I guess I'll be
satisfied with that :)
The hold step in the real circuit conditions :
10u | |\ |
|| _/ | >-+----->
.--||--o/ o---+----+-----------|+/
| 1n --- | |1G
GND GND GND
is also easily trimmed to under 1uV.
The only slight minor reservation is that at 120R the RDSon is twice my
target, but I can parallel 2 of them.
When AD asked me to try these parts I asked them what could make these 121x
different from the 44x but it seems they didn't want to answer.
Now I know they work, I'll ask them again and report here if I have some
interesting answer.
For the LTC1043, I promised you to try them and report. I'll do this later,
because they are less than ideal for me and I have not much time right now.
W
Winfield Hill
which AD recommended after some interesting exchange. I must say I
tried them, but without much hope. And indeed... they work amazingly
Which part did you try, exactly?
D _/ S |\
GND GND
full ON/OFF/ON cycle. This represents a negligeable 12pV on my
10uF input cap. I guess I'll be satisfied with that :)
10u | |\ |
|| _/ | >-+----->
| 1n --- | |1G
GND GND GND
twice my target, but I can parallel 2 of them.
Twice the charge-injection step?
these 121x different from the 44x but it seems they didn't want to
answer. Now I know they work, I'll ask them again and report here
if I have some interesting answer.
They must be finally doing the right thing with the old substrate
trick, a proper break before make, I assume.
this later, because they are less than ideal for me and I have
OK, we'll look forward to that.
F
Fred Bartoli
ADG1211.
Not a pb here: this is used to mask a transient. And this will be trimmed.
The really important one is the 4x12pV per step (I'll need 2 switches in
series) which is totaly negligible.
I doubt that's enough. They have to fight to give 0.5pC charge on one
output. 0.15fC is 300 times better.
If the substrate was switched to one of the switch side, this would
translate to probably unattainable matching. My guess is for something like
substrate switched, but to a buffering push-pull follower or the like.
