Wind Energy
Haris
Jun 23, 2011
19
I want to setup a wind mill in my home. How many ratings of a Motor do I require if I have to run Two fans and two Savers???? 120w for each fan and 14w for each saver.
14,490
Hi Haris
what is a saver ?
it all depends, are all 4 devices likely to be on at the same time ? are they 120V / 220-240V AC devices? or low voltage ?. Your "motor" needs to be a generator.
you are probably going to have to look at a generator charging some big batteries then a 12V - 120V (230V) AC inverter
LOTS more info please :)
cheers
Resqueline
Jul 31, 2009
2,848
I don't see why you'd need power hungry fans if you have wind. Simply letting in the breeze would be a whole lot cheaper, efficient, & simpler. ;)
But maybe it's windstill at night in Pakistan, and that's when you want to run fans & lights. You'll need to state how long these time periods are.
