wireless gizmo help needed
ml
does anyone now of a device that has wireless access at least G and
provide both usb and ethernet?
i want to connect a remotely located printer and usb hard drive to my
wireless net few rooms away
i can find wireless e devices and wireless usb but not one w/both
perhaps i overlooked
anyone know of any??
thanks
mike
thanks
Why would you want to do such a thing?
Put the usb hard drive on a real usb port on any computer on your
network.
Disk data rate would be MUCH faster on the local machine
and probably tiwce as fast to any other machine.
Wireless is normally half-duplex. You don't want two wireless
connections between the drive and the user if you can help it.
mike
ml
network.
mike
because i want to access my (network) hard drives wirelessly
i have a few usb hard drives and printers and other things if i could
connect them wirelessly i don't have to move them to where my
wired/wireless router is nor cable them
i could just plug in the hd's and other gear wirelessly and be able
to use them from my wireless laptoptop
etc etc
not quite sure if your statement regarding half duplex is true for
all wireless standards or interm standards but even if so wireless n
is pretty fast and i've tested my hd over 'b' and it works great i
presume as their are so many wireless hd adapters out there they work
ok or good enough prob not as overal generally reliable as firewire
but
thanks
so question still remains if anyone knows of a wireless device with
ethernet and usb and b/g/n please post i'd guess i'd have to support
bridge mode
mike
You don't have to move them to where your wireless router is.
You have to move them to where ANY computer on your network is.
If that happens to be the one that's wired to the router, it will run
faster.
If it's shared on the network, it doesn't matter where it is, it will be
accessible from your wireless laptop. I have my printer and usb drives
and wireless router hard wired to my primary desktop. I can access it
all from anywhere.
Any device that can connect arbitrary usb devices into the network is
gonna have the equivalent of a computer in it anyway.
There is an emerging wireless usb standard. But that's a whole
different configuration issue.
Having said that, I do respect your right to set up your system any way
you see fit.
Good luck,
mike
JosephKK
ml [email protected] posted to sci.electronics.equipment:
and
to my
w/both perhaps i overlooked
thanks
network.
mike
could
able
etc etc
for
wireless n
i
work
firewire but
thanks
support bridge mode[/QUOTE]
Just plug your NAS drives and print servers into your wired-wireless
router. All inexpensive off-the-shelf.
