Alan B
- Jan 1, 1970
- 0
The simplest answer is that Ohm's Law is not a law at all. It's never
true, and it's often wildly off.
Would you care to explain why that is the simplest answer?
You missed this bit: "Well, let's keep it simple." Since I don't have an
absolute-zero chamber in my workshop, I thought I'd leave superconductors
out of the picture. Zat okay?
Because it makes the division meaningless hence harmless.
Sure, but it avoids addressing the "math problem", which actually
doesn't exist.
DJ said:To work with circuits like this, you have to use complex numbers for
volts, current, and "resistance". That lets you have sinusoidal
voltages and currents that are out of phase with each other, and still
be able to do the math sanely.
In your example, the peak current depends on the peak voltage, and the
L and C values. If the tank is driven, it also depends on the
frequency of the driving source.
It? What is *it*? Ohm's Law?
Are you referring to division by zero
resistance in the equation I = V/R? If so, how does Ohms Law make this
division meaningless?
Are you always so obtuse?
Some people like to "what if" everything to death... "what if there was an
infinite number of electrons" or "what if there was zero resistance
conductors". These are very similar to questions like "What if there is a
god" or "What if I lived for ever". The only real thing that can come of
these types of questions is a waste of time(and it can be measured too).
Abstract said:Some people like to "what if" everything to death... "what if there was an
I think people ask these types of questions because they want to feel smart
but are to stupid or to lazy to learn about much more important things that
actually have answers. They can sit around all day asking these questions
and when they don't arrive at an answer they won't feel stupid because no
one else has them either(or could prove them wrong).
It should be a crime to mention infinity outside the scientific community.
No, the lack of Ohm's Law.
As I think I mentioned, Ohm's Law isn't a physical law.
So E/0 is no
different from 99/0; confusing perhaps, but not a physical
singularity.
"R" is just a definition of E/I in some particular quasi-steady-state
situation.
As a definition, and not a physical reality, using it as a
denominator creates no real-world difficulties.
I'm always an electrical engineer, and I don't let definitions get in
my way.
Real circuits never create mathematical singularities or
physical absurdities.
As has been mentioned, there ARE such things as superconductors.
If we grant that the resistance of such things IS exactly zero, all
this means per Ohm's Law is that the potential drop (E) across
the conductor is also zero. I = 0/0 is not a mathematical problem,
it simply tells us that the current in such a case will be limited by
other factors, including (and perhaps especially) the resistance outside
the superconductor itself. We should also note that a zero-resistance
conducting path is NOT a zero-impedance path; it is, even in theory,
impossible to create a zero-impedance path of non-zero physical
length.
Alan B said:No, you didn't mention that. You said that "Ohm's Law is not a law at
all," and failed to explain yourself.
I am not confused by the concept of division by zero. I am confused by
your style of writing, that seems to consist of stating claims and
offering
no examples or evidence. For instance:
"The simplest answer is that Ohm's Law is not a law at all. It's never
true, and it's often wildly off."
I'd like some evidence that you know what Ohm's Law is, and some proof
that
it is never true, and some examples of when it is wildly off. Simple.
That's a statement that must be taken in context. "R" is also a very real
phenomenon of electrical circuits, and your statement may be re-arranged
to
include all the iterations of the E=I*R representative equation. What do
you mean by "quasi" steady-state? How do I plug "quasi" terms into a
steady-state equation?
It presents no real-world difficulties, as long as the practitioner
understands that the number being substituted for is a minute quantity.
Thus using the term "zero" simplifies equations and is not meant as a
precise representation of physical reality. (Bringing superconductivity
into the matter is, IMO, a separate issue, because doing so introduces a
basic shift in the underlying physics.)
I feel sorry for your cow orkers. It must be very difficult to work with
someone who is so loose with standards and practices for which definitions
exist. Are you familiar with ANSI and IEEE? Heaven forbid you ever get
acquainted with MIL-STD! Your career path would be littered with piles
and
piles of discarded definitions. Come to think of it, I've know c
programmers who, similarly, don't let definitions get in their way. Their
products are predictably poor in quality and impossible to maintain.
Radium said:Hi:
If a conductor has zero resistance, then what is the amperage of a
current flowing though it?
Amperage = voltage/resistance
If the resistance is zero, then the amperage is something that math
cannot explain. Anything divided by zero is an "error" when calculated.
How to solve this puzzle?
Radium
Hi:
John said:---
Strictly speaking, current doesn't flow through it, charge does.
Current, in amperes, is defined as the quantity of charge, in
coulombs, which moves past a fixed point in that conductor in one
second.
No, it isn't.
Consider, in the case you've brought up, if the conductor has zero
resistance, there will also be no voltage dropped across the
conductor, and we'll be left with:
E 0V
I = --- = ---- = ?
R 0R
Well, let's look at what's happening here.
If we say: --- = 1
-1
and ----- = 1
-1
it begins to look like if the divisor and the dividend are equal,
the quotient will always be 1 no matter what side of zero it's on,
so it would seem that at precisely zero:
--- also equals 1
After all, how many times can you fit nothing into nothing? Just
once, is my guess.
With that in mind then, the question becomes, IMO, "How much charge
_is_ there flowing around in there?
Let's look at the case of a superconducting ring in which one
coulomb's worth of electrons has been forced into motion around the
ring and that all of those charges pass by a fixed point on that
ring in one second. The current in the ring will be one ampere
because of the number of charges moving past the reference point in
one second.
But, note that that quantity of charge flows when both the voltage
across, and the resistance through, the ring are zero.
So, since:
E 0
--- = --- = 1
R 0
The induced charge flowing in the ring will be what it is times 1.
Which is to say that if 10 coulombs or ten microcoulombs were to be
induced into the ring, 10 coulombs or ten microcoulombs of charge
would be what flowed perpetually.
Unless you tried to measure it...
Abstract said:news:[email protected]...
The fact of the matter is that there are no zero resistance conductors or
infinite precision measure devices or anything like that. These are all
mathematical idealizations of a property that exists in the physical world. ....
Greg said:I'm surprised that dI/dt=V/L hasn't shown up yet in the discussion.
Even a straight wire has inductance. If there were a finite voltage
applied to a zero resistance, there still wouldn't be an infinite
current. There would be a current of I(t)=Vt/L.
Alan said:Pretty soon you're likely to say something specific, but I'm not holding my
breath.
First things first ..... dividing by zero is not in itself wrong! The
correct terminology, by the way, is 'undefined' not 'incorrect' and not
'error'.
