180 -
Days Won
5
Posts posted by admin
Hello and welcome,
It would be helpful if you post here some of the circuits you found that are close to what you are looking to build. What is the distance that the transmitter needs to be from the receiver to trigger the alarm?
I am suggesting to have a reader in place where the pieces will be placed and each piece will have an RFID tag attached. So when the piece come close to the reader it will register itself. Each RFID has it's own ID and will not interfere with each other piece and will interact with the reader only. The only issue i see is if one piece is placed in the range of the reader and another piece is coming in. In this case maybe the reader maybe gets confused, but this is something to be tried.
Is there one specific place where the pieces are placed? or distributed across the board? If't it's one you could use RFID technology but again the constrain is your pieces as they are small. The smaller RFID tag i found is 25mm in diameter.
The Electronics Project Design / Ideas section seems good. No reason to post it again here. Let's follow it there.
In this case i would recommend a microcontroller (programmable chip) that will continuously read an acceleration sensor in all three axes and if these values fall below a threshold for some time (you define it) the LEDs will flash. But to use a microcontroller, some knowledge of programming is required. The electronics part of this project is straightforward. Alternative you can think of an Arduino to power this project. That will make programming of the mcu more easy.
Is this device going to be attached to someone (wearable?) or it will be in a distance from a person?
That's really cool! Can you give us some technical specification about your led cubes?
CoryD, you should normally see the "Drag files here to attach, or choose files.." as you can see on the attachment below. If you can't see it, please report your browser and operating system and also if you have javascript enabled or any antivirus is blocking parts of a webpage such as cookies.
Normal telephone line power runs around 224 K ohms @ -51 DC volts. The current, not sure how to measure it...but its around 1 amp...I guess, not sure. I'm trying to produce my own phone system with 12 call stations. I have watch a lot of youtube vides...but so far, nothings clear that I can get to work. I've been working on this close to a year! When you connect your tester on a hot phone line, it reads -51.9v and when you go off the hook, it drops to -8v. I have tried many things to get 2 phones to talk to no avail. Connecting a 12V Batt to 2 phones connected will turn on....but will not talk. Watching a youtube video show a guy doing just that and they worked! Perhaps new Wal-Mart $5 digital phones won't work? I'm a loss!
I am attaching here 5 different telephone intercommunication schematics that was published on the old version of electronics-lab.com. They are old designs but may still be useful to help you with what you are trying to accomplish. I also have a telephone intercom system based on PIC microcontroller. If you are interested on this also, just tell me.
I connected a 300 ohm resistor to the red wire and 300 ohm to the green wire, using an altered phone "Y", connected +12V (Red) and 0V (Green) and nothing.
Tried to download a picture of how I have it rigged...wont let me.
Do you have an issue uploading a photo on the forum? What's the problem?
How much output current do you need?
I think the photos needs to be fixed.
As a starting point i would post this link: http://www.studentcompanion.co.za/web-based-control-and-monitoring-with-pic-microcontroller-mikroc/
Are you interested for a particular PIC microcontroller?
I have found these articles of using Matlab and Arduino to control a servo motor. Hope you find them helpfull:
http://www.mathworks.com/help/supportpkg/arduinoio/examples/control-servo-motors.html
http://www.mathworks.com/help/supportpkg/arduino/examples/servo-control.html
http://www.allaboutcircuits.com/projects/servo-control-with-arduino-through-matlab/
Today, i have applied another major update on the forum software. Can you check if the upload function works?
It seems like a JavaScript issue. What brower/operating system are you using?
What problem did you experience while editing the post?
My intention is to try the new design for some months and see how it goes. Then i will decide for any change.
The cheapest PCB supplier i have found is this: http://imall.itead.cc/open-pcb/pcb-prototyping/2layer-green-pcb-5cm-x-5cm-max.html
They provide 2 Layer Green PCB 5cm x 5cm Max for 9.90 USD. You may take a look.
Check here how to disable AVG antivirus: https://support.avg.com/SupportArticleView?l=en_US&urlname=How-to-disable-AVG
Also you can download latest JavaScript here: https://java.com/en/download/
I am sorry to see that the problem didn't go away with the upgrade to Windows 10. So I now suspect that something else is blocking the button to appear on your pc. Do you use any special plugins on your browser, like ad blockers etc? Also, have you tried to deactivate your antivirus temporary?
Some users didn't converted successfully to the new platform, so this might be the case, I am happy to see you registering again.
8x8x8 led cube light
Posted
Would you mind sharing it here?
