faizanbrohi
Members
  • Posts
    203
  • Joined
  • Last visited
faizanbrohi's Achievements
Newbie
  1. Does anyone knows dbm to mW conversion . the output power of The Transmitter is +10 dbM , how much will be it in mWatts . ???
  2. hello again , after a long time i am back , and this time i have found two new crystal controlled IC's that suffice my needs , MC2833 FM Transmitter and MC13136/35 and MC3362 FM Reciever IC's . These IC's are crystal controlled and i think they will be fine for my Radio controlled Car. But Will it Work good for DTMF . It think it might. Although motorola does not manufacture these IC's , but these IC's Are available here in Pakistan at a very Cheap Price of Less than a Dollar . The Main Pain in the Butt is finding the crystals and the Inductors Just right and since the Transmitter is low power i have to build a Power Amplifier of 1W/0.5W for it. The Schematics and pinouts are attached.
  3. okay 33 pins are NC which are not connected so this leaves only 67 , out of which 16 are output to led which leaves 51 pins out of which 16 are for DIN and DOUT which leaves 35 pins and out of which only 2 pins are for register select for brightness control and DCLK , the only question i want to ask is that the maximum rating of DCLK is 15Mhz and there is no min or typical value given , so since 15Mhz is maximum so i can drive it with a 1Mhz clock refrence using Timer TLC552 . That is the only question please helppp....
  4. please can anyone help me on this subject
  5. you might have varactors in the opposite direction as in my circuit.
  6. no i think it is somewhat your pulse rate . ;D , like a ecg machine
  7. I am Planning to build a parallel port led dimmer using ti's TLC5904 which uses 8 data inputs for adjusting the brightness or in other words current . you can control upto 15 LED's using this IC . I know how to interface the parallel port But there is some complication in this is , i don't understand what is a DOUT For , DIN DCLK are used for input for brighness control , and there input will come from a parallel port , since a parallel port is a 8 bit ouput from a computer . i don't know why dclk is for , do i have give external clock pulse . here is the ic pinout tlc5904.pdf
  8. But if you can implement AFC on the reciever side , why not in the transmitter side . But i think for my project that radio is sufficient ,
  9. yeah i get it , this means the TX-500 will be rock solid transmitter if it is PLL Controlled . and one more thing the IC i have for the radio is a KA22425 and also it's equivalent CXA1618M , well the PDf is attached . i know it is not PLL Controlled but why it is stable . i also used it to check my walkie talkie and what do you know , it is quite stable also , it was also quite stable with my FM transmitters , i previously build . it also has a LED indicator to indicate if the channel is selected KA2245d.pdf CXA161.pdf
  10. Hello again , i have a question how can i implement a crystal oscillator i found on the net in my modulator and replace the LC circuit . the desciption and circuits of fundamental crystal oscillators and overtone crystals are given here http://hem.passagen.se/communication/txo.html One more thing how can i use it as a refrence oscillator
  11. Well The PCb Layouts for the power meter are made , now its time to prepare the board and practically test it . will update soon
  12. Still i must say that Toner Transfer method is the best , i have printed an adaptor which is 7 to 10 mil and with perfect results . Just using simple glossy paper , which just cost's nothing compared to the photographic method and an iron. i have also tried the Photoresist method but with not sufficient results. i still Stick with The Toner Transfer method . i will show some pics of the board in the next post.
  13. Well here is the schematic of the Power meter . i am feeling a little sleepy , will make assemble and develop the board for the oscillator and power meter , until then astalavista baby !!!
  14. WHy not use a step up boost voltage regulator , like the ti's UC2577 , but it has a bulky circuit and high amperage . i think a small step up boost voltage regulator with 0.5 A and 12 V regulation voltage would be ok . But then again why bother , and just connect the 12 Volt battery pack directly ;D
  15. So if i remove it , it will be ok for DTMF and if i remove it . it will work for voice. now i will post the power meter shortly. one more thing i am putting a 12V voltage regulator for both the VHF power meter and as well as the VHF Amplifer. is it ok.
