12,026 -
Days Won
13
Posts posted by audioguru
If the resistance of R7 or its connections is intermittent then opamp U3 will have an input voltage high enough to destroy U3 and reduce the output voltage.
In my profile I see the box allowing me to upload my Avatar from my hard drive. But in a forum reply here I do not see a box allowing me to make an attachment.
My pc automatically gets all the latest updates from Microsoft.
My browser had its "popup blocker" turned on, I turned it off now and I will try another reply in a minute.
With the 'popup blocker' in my browser turned off, I still do not see a box in my reply allowing me to make an attachment.
A minute ago I made this same reply and clicked on Submit Reply. Then it said "Saving" forever but never saved it so here it is again.
I set my Avatar photo but I still do not have a box allowing me to attach anything. I will check my clock here since it it 9:53AM where I am.
Let me see the time here.
The clock does not show on my post, it might show later
I went to my Profile to try to set the clock here but couldn't find the clock. I found where it said my gender is Female! Ha,ha, ho, ho, haw, haw. I changed it to male.
How do I set the clock here? How do I set a photo for my avatar?
The circuit you found works with any little NPN transistor including a 2SC1623, it is not a Jfet. It has a low input impedance which loads down the signal level from the high output impedance of a piezo mic and the transistor has low voltage gain so if you speak loudly you will make an output.
The circuit you found will not work with a Jfet but will work with an NPN transistor and a low impedance signal source (not a piezo).
A piezo throat mic is a contact mic. Go to http://makezine.com/2011/12/20/collins-lab-diy-contact-mic/ to see the different circuit used for a Jfet preamp for a piezo mic.
There is a similar circuit at http://www.homemade-circuits.com/2014/07/diy-contact-mic-circuit.html but it has the drain and source pins of the Jfet connected backwards.
I followed instructions in Google how to clear the browser cache and clear temp files. I rebooted. I needed to log in here but I still do not see a box to allow me to make an attachment.
Hero and you use an older Windows 7 operating system. I use newer Wndows 8.1 Pro.
You forgot to tell us what the pickup is used for. A guitar? A piano? A drum? The horrible circuit will work with an N-channel Jfet or NPN transistor if the piezo pickup is in a drum.
The circuit will not be a linear amplifier with a high input impedance if a Jfet is used. The circuit is designed to use an NPN transistor but will work poorly when a piezo pickup or magnetic guitar is used because its input impedance is too low.
If an N-channel Jfet is used then its gate must have a 2.7M resistor to 0V, not to its output. Use a 2N5457 or 2N5484.
I still do not see a box at the lower left corner that will allow me to make an attachment. The area where it might be located is shaded a little with the "Insert Other Media" box on the lower right side.
I do not need to use an image hosting service (that loses an image after a while) on any other website I post attachments on so why do it here? The new software here should be fixed so that Windows 8.1 with internet Explorer 11 works with it.
I was going to post the photo of a timer circle (?) that appears for a moment on the left side after I press "make a reply" but before it shows "insert other media" on the right side.
But I still cannot attach anything.
Let me see what happens when I post an attachment from my hard drive:
No. There still is no box for me to click on, allowing an attachment from my hard drive.
I have an ultrasonic dog whistle that looks like that. It is threaded so its length (and therefore its frequency) is adjustable.
Can you see the "Choose files" link ?
I do not see the paper clip nor the "drag files...", nor the link "Choose files". That part of the screen is blank with the "insert other media" box on the right side.
I also see nothing for me to attach anything from my hard drive.
Hero, which operating system do you have? Is it newer than Windows 7?
Your Windows 7 is much older than my Windows 8.1 Pro.
Can you try Windows 8.1 Pro like millions of other people have?
I do not see "Saving..." anymore when I submit a reply.
The properties of your attachment show that it is a URL, not an attachment from your hard drive. I need to make attachments from my hard drive.
I have always used Microsoft Internet Explorer with no problems until this website got new software. I think Admin should download Internet Explorer to see what causes the problem, not me trying another browser (which one, Firefox, Chrome or another?)..
Sorry, I will not use a different browser and I will not change anything because every other website forum works perfectly except this one with its new software.
Another problem is when I finish typing and push "Submit Reply" it says "Saving..." forever and I think it did not work. It should submit immediately and go back to the thread.
I am making this new post to see if there is a box that says, "Drag files here to attach, or choose files" but the box is missing. Instead there is a box on the right side that says, "Insert other media" as I described before.
I use Microsoft Windows 8.1 and Internet Explorer 11.
It looks like the new software for this site does not allow an attachment to be made so we will never see the schematic.
There is a button here that says, "Insert other media" that might allow an attachment. I am attaching a box that says "TEST".
No, it allows only attachments that were made before, or from a URL.
The new software here is a nightmare!
Testing to see if an attachment can be done (drag....?). NOPE!
The MC34071 is no longer made in a through holes package but the TLE2141 is.Can't you buy TLE2141 opamps and maybe a transformer online like everyone else? Go to www.farnell.com and click on the flag of your country or a neighbouring country to see what they have.
About file uploading
in Feedback/Comments
Posted
I upgraded my pc operating system to Windows 10 and its browser is called EDGE. It works fine on other forums so I will try to attach a file here.
Like with Windows 8.1 and the browser Internet Explorer 11 there is no button here for me to click for me to attach anything.
