audioguru
Members
  • Posts
    12,026
  • Joined
  • Last visited
  • Days Won
    13
Posts posted by audioguru
  1. To all,
    Shall we re-engineer this dangerous (expoding capacitors) project and make it work (the author's web-site forum has many complaints about low output)?
    Well, the author recommends "more powerful" transistors, but many have tried 600V, 30A transistors and other ways, attempting to make it work, but nobody has suceeded.
  2. MP,
    Thank-you for unlocking.
    Kasamiko,
    Capacitors have a "ripple current rating" which is related to their internal impedance (resistance) and physical size (to dissipate power) similar to a power resistor.
    In this project, the capacitors are charged to nearly 23V with a very high current flowing through a forward-biased base-emitter junction on one side, and the +24V (center-tapped transformer action) from the transformer on the other side. The capacitors are shown backwards.
    The capacitors are partially discharged with a very high current through a saturated collector on one side, and an avalanching (-7V) base-emitter junction on the other side. When the capacitor voltage discharges to less than 7V then it can continue a slow dicharge through the resistor, for its timing period.
    Therefore the capacitors have very high currents flowing in them which causes "ordinary" electrolytic capacitors to explode.
    But those expensive tantalums also explode (shooting bits of molten metal- VERY DANGEROUS) and there are debates about whether it is because of the high currents, or due to their reversed polarity, in the forum about this project on the author's web-site.
  3. Hotwaterwizard,
    Sorry. No, you didn't say the same thing.
    Using bigger wires going to the pump will not reduce the voltage-drop along the wires going to his castle. The light will still blink when the pump turns on.
    But I see your point that the motor will draw more current when fed a reduced voltage from smaller wires. Won't the increase in current be cancelled by the wire resistance that will limit that current?
  4. MP,
    Most LEDs will not light with only 1.5V, and worse when the battery is exhausting.
    Voltages of LEDs:
    Common Ultra-bright
    Red:1.7V 2.2-3.5V
    Yellow: 1.9V 2.5-3.8V
    Green: 2.1V 3.1-5.1V
    Blue: - 3.1-5.1V
    White: - 3.1-5.1V
    That's why the little flashlights have an inverter inside, and why National Semi uses a votage-boosting circuit in their LM3909 flasher chip here:
    www.national.com/ds/LM/LM3909.pdf
    You probably meant to use a common LED with 2 batteries, a current-limiting resistor and probes.
    Jo_the_dog,
    Do you know how high is a resistance that is infinite?
    Would 1,000,000 megohms fail?
    Please tell us your maximum resistance that will pass, and how much voltage is allowed for the test. There is a commercial meter called a Megohmer, for measuring the resistance of insulation, that uses a battery of about 90V (ouch).
  5. For all,
    In another web-site's projects forum, there was a request for an inverter to provide all the power for an electricity-heated home.
    Numbers such as 12,000 Amps at 12 Volts (144,000 Watts) were discussed! Enough batteries to fill a large garage!
    But they didn't think of charging them by dragging them along the ground behind a motorcycle.
  6. MP,
    With the 8 ohm resistors gone, there is no voltage divider. The pull-down resistors turn-off the output transistors and discharge capacitances, when the driver transistors turn-off. Without pull-down resistors, the bases of the output transistors gradually (as their capacitances slowly discharge though their leakage) "float" down to a voltage level that is determined by their substantial leakage current (which increases with temperature) and so the output transistors don't completely turn-off.
    The Zapco PSU schematic is in Reply #28, and shows 4 paralleled transistors on each side, without emitter resistors.
    Ante,
    Zapco either matched the paralleled transistors, or had good luck.
    Think of emitter resistors as a form of negative feedback. When a high-gain transistor attempts to conduct a large collector current, then that current creates a voltage-drop across the emitter resistor, which reduces the base-emitter voltage and therefore reduces base-drive.
    A transistor with less gain will attempt to conduct less current and therefore will have less base-drive reduction. So the gains of the transistors are equalized.
    Without emitter resistors, when a high-gain transistor is paralleled with a low-gain one, then the high-gain transistor will conduct more current than the low-gain one, which results in unbalanced current sharing. Without balanced sharing, the high-gain transistor may exceed its maximum current and/or thermal rating and blow-up.
  7. Ante,
    How many inverters do we need on this site?
    I think that the other one, the Low Cost 500W (or 700W) recently revised one, should be stripped-down (and will be explained), when someone requests a reduced power output.
    As you know, I expect projects to work the first time, every time.
  8. Use bigger wire going to your house, farm or castle.
    When the motor is turned-on, it will draw many, many amps of current until it is up to speed. A capacitor won't help much unless it is huge and expensive. A high-voltage, high-value capacitor wired in parallel with the motor will lower the power-factor of that big inductance, reducing its power-draw and your electricity-bill a bit.
    The voltage is dropping along the weakest wire between the power generating station, and the point where the wires to the pump and your lights join.
  9. Hotwaterwizard,
    Your "delayed on relay" is a good circuit that will do the job, but with only a 6V supply, the input divider should be changed.
    If you use 220K for both divider resistors, and a 100 microfarad capacitor, I figure that the delay will be about 6 seconds.
    Use another 2N3904 transistor to replace the obsolete MPSU10, and use a small relay.
    The power must be turned-off for at least 30 seconds, or else the next delay time will be shortened.
    Mike,
    Do you understand how to build this circuit?
  10. Hi Guys,
    Why is this simple multivibrator inverter included in the Projects Section of this high-quality site? It is here:
    http://www.electronics-lab.com/projects/power/018/index.html
    The author claims that it will deliver 300W as shown.
    Has anyone built it? Unfortunately, it has problems:
    1) If the parts values and transistor gains are identical, then when it is turned-on both transistors may conduct at the same time and latch-up. Then it will blow the....., well it doesn't have a fuse, so something will get mighty hot.
    2) With only 63mA of base-drive from R3 or R4 (180 ohms), if the 2N3055 transistors have their minimum-spec'd gain, then the output would be only 39W. (I know, the capacitors boost the base current, but only for a moment).
    3) The capacitors cause the reverse-bias maximum voltage rating of the base-emitter junction of the transistors to be exceeded, causing damage.
    4) The capacitors are shown backwards.
    No, I don't want to re-engineer it, I think that it should be removed from this site.
  11. MP,
    I have never heard of measuring the resistance of a tranformer's windings to determine its voltage ratio.
    The resistance of each winding is not only dependent on the number of turns (length). It is also dependent on wire size.
    For a voltage step-down transformer, thin wire is sometimes used for the primary winding and heavy wire for the secondary. They can be overloaded without much heating.
    Also, in a transformer that has one winding wound on top of the other, the top winding will have a greater length, therefore its resistance will be higher than expected.
    Just measure the voltage.
  12. Marsman,
    You could separate the CPU and PSU only if you use very heavy wire (or copper pipes), which is very impractical.
    However, some PSUs have "remote sense" wires that allow the PSU to adjust its voltage to make-up for the voltage drop of long wires that you desire. Maybe your PSU already has these wires but they are jumpered to its output. If so, then cut the jumpers and try it with each output wire (fairly heavy) and each sense wire (not heavy) joined at the CPU.
    Ante and Marsman,
    Have you seen this link? I have tuned-in since December:
    http://marsrovers.jpl.nasa.gov/home/index.html
  13. MP,
    Thanks for posting the article about darlingtons.
    There it is, in the schematic on the 1st page, a darlington showing pull-down resistors, and exactly the same description for their function that I gave.
    Sorry to continue this argument, but ONSemi (Motorola), in their MC34071 opamp, use pull-down current sources on the "darlington" (their wording) input transistors. See the chip's schematic. Most if not all opamps that use darlingtons have this arrangement. The MC34071 data sheet is here:
    http://www.onsemi.com/pub/Collateral/MC34071-D.PDF
  14. Hotwaterwizard,
    Good point about spike protection!
    I was trying to figure out how a positive spike at the collectors of the output transistors can get through their turned-off collector-base junction, and how a reversed-biased diode can arrest this spike. Now I realise that the positive spike produced at the collectors of the output transistors that are turning-off, causes a negative spike at the collectors of the output transistors that have not yet turned-on, due to center-tapped transformer action. Since this negative spike forward-biases the latter's collector-base junction, then it also forward-biases the protection diode, which arrests the spike.
    Those diodes are good protection.
    Another concern: Perhaps you should change your multivibrator to the 4047 type that is used in the other post:
    1) The 4047 has a divide-by-two to ensure that its outputs have exactly a 50-50 mark-space ratio. Yours depends on resistor/capacitor values, parts tolerance and lack of drifting.
    2) I have seen it happen: If your values are the same then both transistors may "latch" during power-on, when both transistors turn-on and stay-on. Then they won't oscillate.
    3) The 4047 needs only 1 resistor and 1 capacitor, compared to all the parts for your multivibrator, and costs much less.
    But if you use a 4047, you will need to add a pre-driver transistor, like the other post, to boost its output current.
    These two projects are getting to be more and more identical!
  15. In order to avoid continuing confusion about knightrider/chaser, for those who have not seen the American TV show, is it possible to include the animated GIF:
    into the project article, above?
    Is it also possible to remove the phrase,"Knightrider" from the Projects Index for the chaser circuit:
    http://www.electronics-lab.com/projects/motor_light/028/index.html
  16. Hi Mike,
    Welcome to this community.
    So far, you have gathered most of the information that you need:
    1) You have a power supply with a full description and its ratings.
    2) You described a purpose: a certain time delay before energizing the load.
    3) You know that a capacitor takes time to charge.
    But the capacitor needs to be part of a timer circuit, which activates a transistor switch. Please look in our projects section for a timer and I'll look too.
  17. Mastrila,
    Your variac, isolation transformer and rectifier diodes probably are not made to have a low voltage drop during the brief but HUGE current surge when the filter capacitor, C1, is re-charged. Therefore the voltage across C1 (at the lowest point of its ripple) probably is too low. Let's call this voltage, V+. V+ must be more than the project's output voltage by at least the total amount of voltage-drops that follows:
    1) The base-emitter voltage of Q4. (0.9V)
    2) The base-emitter voltage of Q2. (0.8V)
    3) The voltage-drop across R15. (1.0V)
    4) The output-high voltage of U2. (1.2V)
    With the project providing 3A, voltage drops above add up to 3.9V.
    Therefore if you want 30V output, V+ must be at least 33.9V.
    A 24VAC transformer, low-current rectifiers and a low-value for C1, supplying 3A, won't give you this. What do you measure across C1?
  18. MP,
    I did not see any function for diodes D3 and D4 since they are always reversed-biased. Pull-down resistors having only about 20mA were suggested to replace them for reasons as follows:
    1) To turn-off the output transistors, fast. Without pull-down resistors, the bases of the output transistors just float down.
    2) To bypass the leakage current of the output transistors and ensure that they actually turn off. The leakage current increases with temperature (thermal runaway).
    3) To discharge the capacitance (the miller effect multiplies it) at the bases of the output transistors quickly. Without the pull-down resistors then the output transistors become integraters with their own substantial capacitance.
    Darlingtons are emitter-followers with their collectors tied together. The miniscule 20mA of current into the pull-down resistors won't affect the amps of current that are fed to the bases of the output transistors.
    Darlingtons are not used for high-speed-switching nor high quality audio because they are too darn slow.
  19. Hotwaterwizard,
    I am sorry, but I made errors when I suggested modifications to your project:
    1) DO NOT add diodes across the transformer's primary.
    2) DO NOT add 8 ohm resistors in series with the bases of the output transistors.
    My reasons are explained in the other inverter post here:
    http://www.electronics-lab.com/forum/index.php?board=2;action=display;threadid=659;start=15
