oladiladio
7 -
oladiladio's Achievements
The manual is already posted, so all I can do is post the tutorial (v4.16). Enjoy my little contribution. http://rapidshare.com/files/8761762/tutorial-eng.rar
Peak reverse voltage or simply means how high the voltage can be over a reverse biased diode. For instance, over a 1N4148 signal diode VRRM can be no higher than 100V. If you apply a higher voltage the junction will be damaged due to zener or avalanche effect. Two ratings who are important for a rectifier are IF (forward current) and VR (reverse voltage). As a non native English speaker I hope I've made myself clear.
A rule of thumb I learned in school: Ure (voltage across emitter resistor) = 1/10 Uv (power supply voltage) Uce (voltage across collector-emitter) = 1/2*(Uv - Ure) Urc (voltage across collector resistor) = 1/2*(Uv - Ure)
Small Cap between OpAmp Input Pins?
oladiladio replied to Shahriar's topic in Electronic Projects Design/Ideas
It is used to block all RF interference. -
Please beware, it's not a free service
Something about Digital to Analog Converter
oladiladio replied to cyw1984's topic in Electronic Projects Design/Ideas
I guess you will have to live with that. When you take a closer look at the specs (page 3) you will see that the zero-code error is between 1mV and 9mV.
