26 -
Untitled_user's Achievements
Some kind of RPM counter
Untitled_user replied to Untitled_user's topic in Electronic Projects Design/Ideas
Hi! I'm back again. I assembled the counter... ;) Tooked BPW40 and ordinary white LED. And of course, there are the problems... 1. It works just fine when I put the diode on one side of rotating disc and transistor on the other, and cut a hole in disc so Tr can 'see' diode in one moment of rotation. (excuse me for bad description, hard to me say it in English :'()... But when I try to put them both on the same side and use reflection from white/black area, it doesn't react. What can I do? 2. OK, this one I belive can be done later, but anyway: how to calibrate the meter? Regards -
Convert your projects in 3D mode
Untitled_user replied to FH16's topic in Spice Simulation - PCB design
Hello! :D After I saw this topic, I immidiately downloaded and tried this software and I have to say it's absolutely awesome. Realy impressed me. Bravo! Thank you guys for reference! 8) -
OK. Lets mess it out! I parallel transformer secondary windings and i get 30V 4.3A AC. And ... I buy OPA445AP's. :o And thing is gonna work. Will it? How? And wich partslist to use? Need I change something more? Cheers... ;D
Hi. There is no way that this circuit will work with my transformer? Adding a parrallel R to trafo output to drop voltage? Current will be too small? Connecting together both trafo outputs is out of question, right? Something else? And I really cant afford 445 OPs to me... international shipping price + $30 for 445's is too much for me ??? :'( There's really nothing to do? Only new transformer?
Hello! ;D I am looking this power supply for some time and I was planning to build it; in fact I still am interessted in this project, but I need some answers, so, please: 1. I have a 30/30 V transformer 100VA total, 1.7/1.7A secondary output. Can I use it? What for output I will get? 2. What can I use instead OPA445AP? ??? Not availabile, and as I hear, expensive. TL081? +-18V will be enough? 3. Wich partslist to use? Modified or original one? I saw a part of conversation about this PS, (not all 60+ sites ;D) and I am confused. I do not need high-end tip-top extreme power supply, but I even do not want PS crashes, overheating etc. Just a nice, good working and reliable PS. 4. I assume that 10000uF/50V as C1 is gonna be just nice. So long...
OK, and thanks a lot! I will buy parts as soon as i get and assembly this circuit... Till then... Cheers! -
Hello, sorry about theese opto isolators... Here is the filtered list... opto.txt -
Audioguru? -
Hi, I see that not a lot of peoples here are using MultiSim... :( Theese switches you can find in Electromechanical components... (component toolbar)
Hi, well, i really don't know wich ones to take... never had experience with photo elements before... but, its time to change it... I atached a list of elements from our 'local' shop... don't worry, it's only about 30 of them... ;D And I'm soory if the choice is bad... we don't have much electronic stores, and what we have is ussualy expensive... Hope it's gonna change some day... So, please find something for me... Have a nice day... opto.txt -
Hi, This was realy quick and professional... Very nice :D THANKS!!! Of course, have a question again: Can you, please, write down some diodes and transistor pairs that can be used..? I looked online catalog here by us and it's a bit confusing... And, I supose that now I can directly drive analog meter form output, isn't it? Marc -
After long time, hello again... I'm back to bother you... Audioguru: I would ask you something: Would you, please, be so good to quickly sketch a schematic for me? I see that if we (better said I :-[) continue so, we would come nowhere... I belive that would not be too big problem for master like you... Please? And if answer is yes, i would like Vcc something like 5 or 9V... Marc -
Hi, I was thinking a bit about that counter... I redraw those schematics and now I'm posting them; one with LM2917, and other with 555 timer. I do not know if this one with LM will work, but it looks damn simple ;D And if I use the 555 circuit, I will anyway have to use freq. to voltage converter at output, am I right? I think that would be time to pick up way to go, so, what do you sugest, and why? -
Well, on this schematic from datasheet, I actualy wanted to ask if magnetic principe could be somehow changed with optical... i forgoted :) I belive that magnetic could not be used, beacuse it's about electric motor, so it will disturb the work of counter... And on this design with 555 I should add a freq/voltage converter to drive a analog meter, isn't it? So, i dont know what to do... the both solutions seems to be quite good, simple and cheap... And I ask you, masters of electronics: what to do? I'm gonnig in electronis school, we courently learning basics about analog and digital electronics u know: transistor amplifiers, multivibrators, digital logic, TTL, CMOS, voltage ragulators...so I belive that I soon wont bother you with such simple projects, and I could design some circuits at my own... ;D And by then, I would appreciate a little help... Marc
