I am a beginner at electronics and am trying to create a circuit to use small frequently-polarity-switching induced currents to generate a constant current flow for power generation reasons. I understand that if I use a conventional rectifier circuit the supply voltage must be larger than the 0.7 volt drop caused by the diode. I think I will also have this problem if I use a microcontroller and BJT. Also if I use a "precision Rectifier Circuit" which utilises an Op Amp I will have to power the op amp, thus reducing the power generated. Does anyone know of another solution or have any ideas for this problem? Thanks Tom
