mvs sarma
234 -
Posts posted by mvs sarma
Hi
This is rightly said to be a mutual inductance demo kit -
Hi HERCULES
welcome
BC158A cPNP transistorv an be substituted by 2n2907A taking care of the pin differences
SL100 is a medium power device, and if from india, you get CL100, BEL100N
otherwise, you may perhpas try BD115 -
congrats
please post a photo of the pcb assembled by you as .jpg -
the voltage drop across highspeed diode is more than that of a schottky diode
the working voltage ,if it is less , we will be adding further voltage drop, thereby reducing the voltage to the actual load. that is why perhaps they prefer to yuse schottky device. -
Hi
you could use say IN5819 series. -
Hi
Recently I saw one circuit of steth with pizio buzzer element (two tagged) as sensing element. -
I need a RF transceiver operating in the ISM band or so, for local data telemetry using FSK or ASK, in a DIP or PDIP form, that i can request as a sample(i.e. for free).. Any ideas? I know it's cheap of me, but in India, component availability is very suspect. Please help me guys..
Hi
try www.sunrom.com
they offer STT and STR 433 a set . in Indian Rupees and at $ rates aswell
Hi all
let us honour the rules of the site and also protect the MAGs' rightseven-- afterall it will cost us few bucks prchase-- imagine a robbery inour own homes??? pity -
Hi
even for FUn to expect reply from 25000 appox membership -- think of what are you expecting from this form with HUGE membership-- an impossible task and this site will be filled up for nothing but so called fun-- good i am also on power electronics while worked for telecom.-- -
Hi cynicmonster
welcome
please download and see this pdf
you will surely be enlightened
www.audioprecision.com/bin/AMH-1.pdf
check for psophometric weighing etc -
Hi Indulis
i had recently visited an enrgy saving exhibition at Hyderabd, wherein M/s NMDC (national minaral development corporation), participated --which enthused me to probe their participation cause--
they have apeculiar cituation and use it to regenerate power and they gave a brouchre
it is rather dificult o post it here -- but i suggest you to see their website
their regd office is located at Hyderabad -India
www.nmdc-india.com -
Hi
try IR LED and Photo tranasistor on either side to sense the car passing thro breaks the light path --use thr Transistor outputs to trigger set / reset flip flop
-the output could drive a relay with change over contacts to reverse the power to the motor -
Hi
audioguru is right in saying not make CHEAP kits. in general many kits are costly perhaps due to limited volumes sold, as compared to finished products.
members prestigeous fourms like e-lab.com shold comeforward to be able design and realise instead of ckd or skd assembly.
Here also, as Audioguru once put it -- we will be able to assemble but not give a finishing to it with a proper cabinet or a housing.
If these are done for the sake of experience(hands on ) then the extra cost is worth it as person gains practical knowledge which will be a factor to deside his/her future. -
Hi
such nice info (thanks Hotwaterwizard) i do recollect my training days.
perhaps the clock being 4MHz, even CD40 series (CMOS)can work and with llower power consumption. ofcourse the proper pin outs shold be followed.
sarma -
PLEASE TRY THIS Color VGA Adapter
Pin# Label Function
1 RED Red color signal
2 GREEN Green color signal
3 BLUE Blue color signal
4 ID2 Monitor identification bit 2
5 N.C. Not Connected
6 GND-RED Ground Red signal
7 GND-GREEN Ground Green signal
8 GND-BLUE Ground Blue signal
9 N.C. Not Connected
10 GND-SYNC Ground Sync signal
11 ID1 Monitor identification bit 1
12 ID0 Monitor identification bit 0
13 H-SYNC Horizontal Synchronization
14 V-SYNC Vertical Synchronization
15 N.C. Not connected
SARMA -
HI
FOR EXAMPLE A VGA MONITOR BY DELL HAS INDICATED IN THE SITE BELOW
http://support.dell.com/support/edocs/dta/NL25/00000005.htm
PLEASE TRY OUT
SARMA -
hi
the circuit shold have been shown fully instead of masking valid portions-- thus it appears deliberatein the sence, it may perhaps be a question in an exam? right!!
the dual caps and ajuper near the bridge provide forchange over between two versions of incoming AC Supply -- like 110 V/60Hz of Japan, US, even canada if i am right; while 230V/50Hz in most other countries.
Others Qs are to be thought over
sarma -
Hi Covalier
First convert the 6V AC to DC , filter it
Then use a MC34063 ic with few other components in a boost mode to say 15V DC
Have an additinal filter for reducing harmonics.
12DC is ready
see the datasheet attached
All the best
sarma -
hi
do you really need to substitute-- why not, if possible original 74390 or 74ls390
if need to do.
make a small adopter board with berg pins at the botom to suite t4ls390 pin ot and put 2 nos 7490 on topnear to the pins and try hard wire.. -- laborious job--
sarma -
Hi
audioguru is RIGHT
the IC is quad opamp
sarma
ps thanks audioguru -
Hi
please see any datashhet for LM324
it an ic with four similar circuits called comparator.
each one can compare two input signals and out put a +ve voltage or a near earth depending on the comaprision. this just in plain english approximately. for datails see the datasheet at sl No 12 at
http://www.electronics-lab.com/downloads/datasheets/ic_analog.html
sarma -
Hi
perhaps the attenuation out side the audio band depends on the % tolerence of the components you use across the filter like the one suggested by Audioguru
Try toassmble one and run a test with a set of frequencies,say , from 200Hz to 4 or 5KHz and tabulate you will know the filter behaviour.
you may have the set up at any lab near to you.
sarma -
hi Hotwaterwizard
SO NICE A Resonator
like to see it in 4th dimension--(i mean some one performing on it
sarma -
hi Mic3ca
whynot keep diode series to the resistor while reducing the 100k to say 1k as it is for base current limiting and the series diode can effectively block the -ve signal from RS232. ofcourse you could terminate the base with say 100K
sarma
what should i do about computer rf emissions?
in Electronics chit chat
Posted
Hi
Take radio to a better location not in in vicinity of TV or computer or any device using SMPS and crystal oscillators.
