hangmotion
6 -
Everything posted by hangmotion
New Member Need Help !!!
hangmotion replied to hangmotion's topic in Electronic Projects Design/Ideas
thanks logan_dslasher and balong for answer i still want it please post it for me thank you for every thing -
I'll use my 100W amp to amplify a surgical equipment call electrocautery which use 300kHz to 1MHz to cut tissue I'll not use it with any radio transmitter now I try it with solidstate mj15003 mj15004 with 100W power but output is very very low so i decide to do with RF Amp Please help me I don't know any thing about them
did they can produce 100W at 300kHz and how to make it input is fuinction generator ,sine wave 1V and need output 500V 0.2A Thankyou
My Project is Electrocautery I'm working on it for my teacher it use as an surgical equiptment it use electric current trough tissue when we touch the probe to the skin .because the surface between probe and skin is very few so there is a lot of resistance then electric tranform to heat and vaporize the cell's water then the skin will torn. the most effective form is normal sine wave with 300kHz to 1MHz frecquency 340V up to 2000V with 100 to 500 W at 400 Ohm 0.5-0.1 A what should I do with this project i think i'll use function generator and amplify it and then use output tranformer to multiply voltage in first try I order adjustable function generator with 1V output at 330kHz and 150W mosfet sound amplifier and told to remove filter but the result is there is very low watt output and he don't know what to do next please help me solve this problem or please tell me what amplifier that can amplify this frecquency and I may asking for 330kHz function generator circuit may be with 555 or LM741 Thank you Tossapron
