zhiling0229
10 -
Everything posted by zhiling0229
Hi guys, I'm trying to build an embedded system wave file player. This is the block diagram for this system that I thought off. A microcontroller will receive an input. The microcontroller will fetch the desire wave file from the EEPROM and will send to the D/A converter and output it to the speaker. Is this workable? Need some feedback and some circuit layout would be nice
Converting negative analog voltage to positive
zhiling0229 replied to zhiling0229's topic in Electronic Projects Design/Ideas
Thanks Audio guru your a great help ;D, Was wondering is there an alternative method instead of using another OP-AMP. -
Op-amp or trans-impedance amplifier
Thanks Audio Guru, I think I have resolve part of the problem already. I'm posting a new problem in the community board hope you can help out. -
hi audio guru, I am not performing any modulation but I will be using my operational amplifier as a current to voltage converter. converting a maximum of 11.4 uA to a maximum of 2V. Do you any operational amplifier that requires a maximum of -
Thanks audio guru. But it looks kind of complex. ;D I will be using a UV photodiode which the wavelength is from 200nm to 320nm therefore the frequency will be in THz. I don't think i can filter it using the circuit. Here are the two circuits that I plan to used circuit 1 is using a general op-amp and second one is using a transimpedance amplifier. both will require to produce output in the range of 0 to 2 V(max) and the photodiode will produce a maximum of 11.47uA. Please comment on the circuit. Thanks -
Hi guys, I'm a newbie. I'm working on an amplifier for my photodiode project. I was wondering which has better performance a general purpose op-amp with a feedback loop or a trans-impedance amplifier or is there a much better way to amplify the current? I'm open to any suggestions. Thanks
