JonathanFilippi
Members
  • Posts
    8
  • Joined
  • Last visited
Everything posted by JonathanFilippi
  1. Costructive criticism is the key for technological improvement and learning :)
  2. I'm not discouraged ;), answering questions and solving doubts is funny, also Audioguru started an interesting discussion. The power supply is easily scalable up. With those heatsinks the mosfets should hold up to 300W (but with fan), the important thing is the transformer core, that must be sized accordingly. Also the turns strenght must be increased or they will heat up and reduce efficiency, the diodes too must be be increased, maybe using higher current capablility shottkies. The reason that i scaled down the power to 30W is because i have 20W speakers on hand (and probably i cannot go farther than 20W without blowing them). I'm building a small amplifier for a small car, to be used with an mp3 cd player. (suggestions with the Lm3886 amplifier are welcome Audioguru)
  3. Of course it can be designed very easily to output +/- 30VDC per rail. This can be accomplished varying two things. First the turn ratio (instead of 1:2 using 1:3) and downregulating to 30V via PWM (adjusting the voltage divired feeding the error amplifier accordingly). If you want to change the turn ration without changing primary turns (and so the switching frequency), you can use 5T /15T of litz or multiple wire (more wires in parallel to reduce skin effect). This design can also work at 35V if you keep the input voltage at 12V (though it may drop due to wire resistance/battery resistance). Since at 30V the power will be higher the core size must be increased accordingly, or the switching frequency (but this will higher the hysteresys and switching losses). You may try 3:9 or 4:12 with a higher switching frequency. The TDA1562Q is marvellous, probably it is used in most car amplifiers . But what does mean class-H ?
  4. Thanx for the advice. I will use the caps on the amplifier input (1000uf+100nF for each rail near the amplifier). Anyway even it is noisy because of ripple, the noise is in the ultrasound range (areound 50KHz), so it will not be heard
  5. You are right, but only at half. I'm claiming 50W output power on
  6. This circuit itself is a crap... Better is to use a 555 with duty cycle to 50% and 50Hz frequency, Two mosfets with respective gate driver and a half tapped transformer with the rating needed to get the power required.
