grmahun
6 -
Everything posted by grmahun
gating signal for six MOSFETS or SCRS
grmahun replied to grmahun's topic in Electronic Projects Design/Ideas
Hi, Ante. Sorry to be late. The original project is to feed an ac induction motor using voltage source inverter(VSI).So this first needs dc input from one of the following: battery(solar power),diode bridge rectifier or chopper.Using this as an input the inverter gives an output of AC.But this AC is variable in voltage and frequancy magnitude so that the torque and speed of the motor can be controlled. -
Thanks Ante,I think the source from the battery makes the design more difficult than I thought.How about if the source is from mains using step down transformer and rectified to 12v DC. -
Does that mean there is no alternative to drive a 3 phase induction motor from car battery or solar source for at least power output of 1hp. -
The expected output ratings : 3kw,380v(L-L),50HZ The phase shift 120 degree including dead time generation between the gating signals of mosfets in one leg. There is no need of to get perfect sine wave it can be square wave because this inverter is used to drive 3 phase induction motor. I think IGBT could be better as posted by Ante but we have only accese to mosfet in our lab.The DC could also go up to 48V. -
I want to design a three- phase, 380V,50Hz inverter from a battrey of 12 - 24V dc source. This needs six pulse gating signal for the six SCRs or MOSFETs. Could you please help me with the design of these gating signals. TQ in advance.
