supes
12 -
supes's Achievements
Need help with 3916 super project
supes replied to supes's topic in Electronic Projects Design/Ideas
Checked all that you mentioned. Nothing. I will lay low for a while till I can get some stuff sorted out and I get the stuff I need from DigiKey. Until then, I am humbly greatful for the insight and time audioguru. You are the man :) -
I tried a different electret mic. It is now reading 1.44VDC. The mic I had may be bad but it still isnt the solution. Going through the pins I get : pin 1: 2.34VDC, 4.6VAC pin 2: 2.34VDC pin 3: 2.34VDC pin 4: 0VDC pin 5: 0VDC pin 6: .08VDC pin 7: .51VDC, .6VAC pin 8: 8.14VDC -
So after a little while working on it today, here is what I found out. Pin 6 after the R9 is getting virtually nothing (.08VDC). We have ~2.5V at pin 1. When that goes through C4 we end up with the .08VDC that goes into pin 6. If I wanted to test the microphone alone, would I put the meter on the on the non-gnd side of the electret mic. When I do that I get .22VDC and .2VAC. I adjusted music volume and the DC voltage didnt budge. Is the microphone not being driven enough to actually work? Could that be the problem? -
What were your values for pins 5, 6, and 7 of the amplifier? Or maybe a better question, what are the ideal values for those pins of the amplifier? I remember you saying that pin 7 should be between 1 to 4 VDC but I am lower than that. -
Error on my end. Pins 5, 6, and 7 are 0, .09, and .52 VDC respectively. However, I still did replace it. Pins 5, 6, and 7 are 0, .09, .52 VDC respectively. Funny that they are exactly the same. Sorry for the error. -
I think I may have been unclear. The pins 1, 2, and 3 of the 358N are all 2.36 VDC. The output pin I was talking about was pin 7 of the 358N. For the second ampifier in the 358N. Pins 5, 6, and 7 are 0, .9, and .52 VDC respectively. Pin 7 or atleast that set of pins is the problem I think. -
Maybe the fact that i dont have a 3915 is also limiting my progess. I checked pin 1 and it was infact 2.44V. The output pin was .66VDC. The electret mic is at 1.94VDC. Pin 5 of the 3916 is at .15VDC and pin 6 of the 3916 is .48VDC. So now, where is a good place to get the LM3915 for a fair price. I want to order a few. I will continue to work on this on my own in the meantime :) Thanks for you help audioguru. Also on another note, I want to make the 'Knight Rider' lights and remember reading that you did not like the 4017 version b/c it wasnt smooth. Have you come across a circuit that does a better job of make the effect? If so please share. -
Yea I was afraid of the microphone not working. I can hope that it might be the pre-amp. Anway I did change the resistor you mentioned and I get a bout .18VDC at pin 5 and .49VDC now. Would you be able to recommend another pre-amp that would work with an electret microphone and give a good level to drive the 3916? I have 4 electret microphones that all look like the one i posted. All are new. I also have the 2904 386 1458 324 just incase I will need to use them -
Okay I found 2 resistors that were sorted together. I am getting somewhere now. I am getting .1VDC at pin 5 of the 3916 and .24V at pin 6. I turned the POT down and I have only a few LEDs light up now but now still move. If I can get the pin 5 voltage up from the microphone (dont even know if the microphone is working yet) I may get the whole thing working as it should. I have .49VDC at pin 7 of the 358N. What am I doing wrong? Why is the signal only .1V? -
So here are a few points that will hopefully help you understand my situation better. 1. I am using all 3904's 2. I am using the 358N and I know it will be more of a 'beat' meter than a frequency type since the 358 is limited to about 4kHz. 3. At pin 5 of the 3916 I get 6.9DC and 14.x VAC which seems like overkill and is probably the reason all LEDs are on. Therefore I think the problem is in my pre-amp stage. 4. I attached a picture of my electret microphone as I am not sure if it is one that would work with this circuit. Circuit with all LEDs on Microphone (using one on left) I will continue to work and update the situation. Thank you for the help and the warm welcome audioguru! -
So I have big hopes for my LED project. I have been stocking up on high quality LEDs and rechargable batteries just for this project. Anyway here is the problem. I am using LM3916 drivers, and alone I can get it to do what I want with the signal (from sound card) connected directly to the input of the IC. I used this as reference. Now, I wanted to make this wireless so I got a couple electret mics and tried using this as a guide with my 3916 and hoped it would all work out. http://www.electronics-lab.com/projects/motor_light/009/index.html However, I just have all LEDs on all the time in bar mode and the last LED on in dot mode. I dont think the microphone part is working or else there is something wrong somewhere. I followed the schematic exactly (minus the 1W resistor) and have been going crazy going over looking for any mistakes. I tried changing the POT to all values and nothing changes. It is also worthy to note that I used a 358N IC for the pre-amp and my signal into pin 5 of the 3916 is 6.9V. I am asking for some help now since I am stumped.
