180 -
Everything posted by pier
Everything in chineese !!!!!!!!!
Hi AG Assuming the current drawn by each LED is 350mA . I have connected a 500mA transformer for the whole circuit . Now to make 5 LED's work together, Will it be good to put them in series with a transformer of more o/p voltage? Because the i/p to the regulator is maximum 40 volts i guess !! I am not sure. Will it be safe ?
Thanks Ante I've got the Idea now .
Hello AG Philips has a certified a manufacturer for this http://www.polymer-optics.co.uk/Supa-Hex%20Range%20(Luxeon).pdf .
Hi Ante Do You mean the outer diameter of the knob should be big for lesser torque we apply, so that it goes smooth ? Can u give me a picture of the knob you use ?
Hi AG I've seen some lens specially made for luxion 1 watt LED's at http://ledsupply.com/l2-op-025.php . What is your suggestion on this ?
Thanks for the value AG but is it a standard value that we get ? . I feel ante's selection is a good one but do you call them a multiturn pot ? or does it have a specific name ??? ?
Hi AG So is the 100 Ohms pot fine for the fine tune . What should be the value if i need to get a fine tune of one volt ?
hello esp1 Actually i just guessed with no practical calculations . But since u say its going to be fine i just have to try it out . But since AG said you should reduce the value of the existing pot as well, I am confused .
Thanks a lot AG , I was about to wind up after shaftons reply . Will this changes be sufficient ?
I have made the 0-30 volts lab power supply which is there on this site . I want to know if it was possible to add a FINE TUNE provision for accurate selection of the O/P voltage . Please help me .
Hi AG I connected a 11 Ohms resistor as the load . I noticed that the o/p voltage of the lm317 regulator was 3.6volts dc when the input voltage to the regulator was varied from 7.82volts dc to 17volts dc . The lm317 is cooler then before now . Is this enough AG ??? as the forward voltage for the led is 3.48 volts dc ?
Hi AG Then I will have to use a 9 volts 500mA step down transformer. Will that give enough voltage for lm317 ?
Hello AG The LED forward voltage i measured is 3.48volts . So it wont be sufficient na ?
Hi AG So I would have to use a 6 volts stepdown 500mA transformer,bridge and a filter which would give an o/p voltage of 8.64 volts dc across the filter capacitor to reduce the voltage to lm317 ?
Hi AG What should be the resistor value instead of 3.9 Ohms if i put only one LED ?
Hello AG Could these heat sink be sufficient for the regulator ? I first used PI49 and found the regulator over heating .
Hi AG Since i am weak in electronics i am getting confused . In the ckt the 3.9 Ohms is connected from o/p to adjust terminal so when the LED's are drawing 350mA current, then is the current flowing through the 3.9 Ohms resistor ? Or from where is it drawing current ?
Hello AG One more doubt before connecting the load, should the 3.9 Ohms resistor also be 2 watt ?
Hello AG, Can I put a 25 ohms resistor in instead of the led's to see the voltage across it ? If so should it be a 2watt ?
Hello AG The o/p of the lm317 is 15.45 volts(open voltage). Will it harm the led's .
Hi AG Which is the ideal resistor to be used in series with the LED to find out its exact forward voltage ? I have a 6volts battery as a source .
Hi AG Thanks a lot for that . What will happen if the input voltage rise beyond 230 volts, as i measure 17.3 volts at 1000uF capacitor . And what is the calculation for finding out the o/p voltage of the lm317 AG ?
Hi AG, So the value of the resistor is 1.2ohms ?
Hi AG, Should i take tho o/p at pin 2.
