Staigen
695 -
Posts posted by Staigen
No no no! Not your decoupling caps, your coupling caps! ???
A little schematic would be fine too! ;D
//Staigen -
Hi
I got some kind of "microphony" feedback
Sometimes ceramic caps can act as a "microphone", can it be this behaviour of
ceramics that cause your problem? Do you have any ceramic coupling caps in your circuit?
By using a 3.6V zener, properly biased, i belive you can hear its noise clearly by
using only a 386 Amp at 200 times amplification!
//Staigen -
Hi all
Tony_Stoynov have encountered some strange behaviour in some 78xx regulators. I dont recognize
this, but maybee someone else have had this problem too. We let Tony describe the problems he
had, and he's remedys. Maybee someone also know why.
//Staigen -
The battery was not in the compost, it was outside, behind a wood wall.
And the worms comes up fast if you put 220V in the soil. ;D ;D
//Staigen -
Hi
Well, i dont know how i should put it, i'm not so good in the enlish language ;D
When i was young(10-15years old, about) we had an angry gardener living
here, and when we where there, trying to steal his vegetables and fruit, he
was hunting us, and to revenge we put a 1.5V battery cell with wires to his
compost. The wires was buried in the soil at each end, and the battery was
hidden behind the compost, digged down a little, and the compost did not
work. This was done in the spring, and in the spring the next year he found
the battery and reported it to the police, but they didn't cought us. This "trick"
was told to us by one of the fathers of my friends. Also, when we was going
fishing, and needed worms for the hook, we put 220V into the ground, and all
worms around immediately turned up above ground, several meters around.
As you see, i havent always been a nice guy 8) :P ;D
//Staigen -
What does faceplant's second formula stands for then?
//Staigen -
Staigen! anybody! HELP
Who? Me? I dont remember, i was in the elctronics scool at 1963-1965!
But i have a feeling that the first one looks like the formula for inductance,
but i'm not sure.
Is the second one the formula for inductance? Isn't it for something else?
But i'm not sure here either.
When i construct coils i use nomograms and programs.
//Staigen -
Hehe, we are really offtopic now ;D
Maybee you should help f4cepl4nt with his question.
//Staigen -
Its okay Logan, but it clutter up the forum, just like we are doing now :P
//Staigen -
Hi Logan
Why didn't he delete this one then?
//Staigen -
Hi
What have TV:s to do with inductance? ??? ??? ???
//Staigen -
I agree with you Audioguru, did you see the "wink" at the end of my post ;)
//Staigen -
Hi
Let me carify Staigen, the speaker terminal output of the Plasma is rated at (16W (8W + 8W) into 6 ohms) whereas my component amplifier is 80W
OkUse a 10 ohm 5W resistor across the plasma's speaker terminals for load
Dont you think 10 ohms resistors will give rise to crossover, use at least 47 ohms
resistors.Couple the RCA male ends to a ground loop isolator, and then from the isolator to the component amp
That will be just fine, but, you must have at least one ground connection between the
two. A little schematic will clarify things.
//Staigen -
Hey, where is my replyes, they where here just a minute ago?
And Audiogurus reply is gone too? And someone have changed
Antes reply too! What is going on with E-Lab? I dont recognize
it anymoore! ;)
//Staigen -
Hey, that pictures wasn't there before! So it is a model motor, a glow plug
engine. Why didn't you tell us that earlier?
Reduce the compression, and it will not preignite that easy!
//Staigen -
Hi sinn
If the diesel engine you have is preigniting the fuel injection pump is
adjusted wrong. Maybee there is something wrong with the injection
nozzles too. If the engine starts to glow then run for your life, it's soon
will explode, and you can get hit by parts flying around! Why do you run
it with fuel that it is not constructed for?
//Staigen -
Hi
To awright:
I could not have saying it in a better way myself. I aggree fully with you.
To shaiqbashir:
I will make a little schematic for you, and put it up in your other thread, the one
about your stepper motor.
//Staigen -
Hi robinnnn
Have you tried the manufacturers site, often you can ask questions about
their products there?
//Staigen -
Hey, come down, both of you! :o
//Staigen -
Hey premece, watch your language, and havent you learn to write in scool!
//Staigen -
Hi
What kind of gardeners are you two, dont ever put any kind of current into a
compost, the compost will die! The worms shy electricity to every extent! And
the bacterial culture dont like it, and go to rest, and will die soon.
//Staigen
Help: White - Pink Noise Generator
Posted
Okay, its your project, good luck
//Staigen
