Staigen
695 -
Posts posted by Staigen
Hey Serge, do you know something about APF's block list, a file, i belive, that block IP numbers or adresses? Probably used at internet servers. Anyone else know about this list? Its purposes?
//Staigen -
Hi Zeppelin
Many of us can't reach E-Lab at the moment! Not me, until now, not Ante, not Audioguru, and how many more that can't reach E-Lab at the moment, i dont know!is stated to be 0.5%+1?
This mean that the accuracy is 0.5%, plus/minus 1 number(count)
//Staigen -
Hi Serge
I also want to say welcome to the forum! Nice to have you here ;D
The font mess come from this board!
Hopefully you will enjoy, and we hope you come with lots of reply's, questions and discussions! ;D
//Staigen -
Hi circuity
Try to get a copy of the book "TTL COOKBOOK" by Don Lancaster, and read it, specially the chapter about intefaceing to real world. :)
I belive amason.com have it, or at least a used one.
You can also try to borrow it from your local library.
If you found it as an E-book, please let us share it!
//Staigen -
Hi, sorry to interrupt
One big error here, the yellow wire in a standard computer molex connector is 12V, and the red one is 5V!
Maybee also the 5V regulator is connected wrong then! Check!
//Staigen -
Hi
Isn't diff op-amp short for differential operational amplifier?
Isn't op-amp also short for differential operational amplifier?
Then your question dont make sense to me! ???
Correct me if i'm wrong!
//Staigen -
Hi Inuyasha
No problem downloading or extracting that file, its a PDF file with total service instructions, if you want to, i can upload it here, as a zip file
//Staigen -
Hi fredigsm, velcome to this forum ;D
Its right here on this site, in the projects area, here is a link:
http://www.electronics-lab.com/projects/pc/index.html
Have fun! ;D
//Staigen -
Hi John
Have you looked in the EPE jan 2003 mag? I also have read about it in an article from 1930!
//Staigen -
Hey John, this wont give much out, there's an error in the drawing!
The supply shoud be connected to the connection between the 1K resistor and the pot instead! Sorry
//Staigen -
Than you have to do your math then!
Are you from Sweden?
//Staigen -
Yepp, i know that, and you know that, but the guy that wrote the book dont seems to know! Also, we dont know the answer or the facit yet, will you supply us with that, Sundin?
//Staigen -
So you like to do others homework, Audioguru?
Well, i belive some of your answers will turn out to be wrong, too, in this teoretical questions! ;D ;D ;D
Hehe
//Staigen -
Hi there sundin13, velcome to the forum! :)
Sundin? Sounds like a Swedish name. Are you from Sweden?
Some of the questions cant be answered, because there is a lack of some parameters!
Vbe, for instance.
But asume it is a perfect transistor(such transistor dont exist!) with a Vbe of zero votage and DCbeta=162.
Question a:
Since Vin=0V then Ib=0mA(uA,A), hence also Ic=0mA(uA,A), then the voltage across Rc=0V
Question b:
This one is harder, but it is only math! First you have to calculate the current throu Rc at saturation, then divide that with the beta value. If you calculate the Ic in other values than uA, then you have to convert the answer to uA.
Question c:
Here you can do the math in two ways. First way, divide the Vin voltage with the Ib current in uA, the answer is in Megohm, than convert to Kohm. Second way, convert the Ib current to mA, then divide the Vin voltage with that value, the answer is in mA.
But watch out, there's a trap buildt in in this anwers! The trap only affects the c question. ??? ;D
I belive you see the trap at once, once you have read throu the text once more.
//Staigen -
Thanks to you too keldean, i did not have some of the other!
Then i miss most of the 2004 EPE Mags, have only jan and feb!
//Staigen -
Watch out EPE 2005-05 seems to be a stripped off version with no possibillities to manouvre in! Here is the full version
//Staigen [attachment deleted by admin] -
Maybee December would be nice too?
And November!
September? Here it is, hopefully! ??? ;D
Hi Logan
I found the appnote on my computer in the end, it was not in the book! ;D
I found two versions of it!
Here they are:
//Staigen -
But wait there's moore's law
Ok, but how goes "moore's law" ? -
Hi
There is an aplication note fron RCA about this, i will check later for the name of it!
//Staigen -
Hi Logan
Your adviser is totally wrong, it can be used as an amplifier, and a good amp too!
You almost had it working when your adviser took it apart from you, he should be ashamed!
//Staigen -
power on reset for digital circuits
Posted
Hi there Sukhbinder
Cmos or TTL?
//Staigen
