591 -
Posts posted by Dazza
Hi MP, Ante,
There was a new story on TV tonight about the cost of running an air-conditioner, they said that it cost about 80 cents to run an average air-conditioner for an average size bedroom for 10 hours, that is for an air-conditioner around 950W.
So it looks like I won't have to climb that very tall light pole after all ;D ;D.
I have about 80 percent of the furnace finished :), I now have to wait a couple of days for the refractory to cure >:(. I decided to hold of making the new light dimmer switch, and use the one I have, just for the heat treatment of the refractory and to get an idea on how it is going to perform. Then I'll make the new one, and see if I can't melt some aluminium ;). I managed to add an extra heat sink to the existing one, so it will now continuously run at around 1300W without any problems. -
The project involved, potentially lethal high voltage. [iurl]http://www.electronics-lab.com/forum/index.php?board=24;action=display;threadid=2544[/iurl]
Good find rasOfir :D,
I'll have to take on that project as well, when I get the chants :).
There's a lot of FM transmitter projects out there, yes that can be difficult choosing the right one ???.
Have a look in the projects, you might find something to your liking( http://www.electronics-lab.com/projects/rf/index.html) -
You are probably right MP :), although I don't think there would be a significant difference in cost to using gas, it would really depend on where you are from, cost of gas/LPG and electricity in your country.
Once I get every think up and running, I'll workout the cost of electricity to produce a certain volume of melted aluminium, it may be difficult to compare the two, as I haven't come across any information of cost of gas for a melt. Although if I find the cost of electricity to excessive, I will soon knock a whole in the bottom of the furnace and put a burner in their ;).
mixos, Thanks for the article I haven't read it all yet, seems a bit to advenced for what I need, but you never know. -
Hi rasOfir, and welcome.
You really need to know what you're doing to take on such a project.
I have made an FM stereo transmitter using the (BA1404) FM stereo transmitter IC, for the same reasons you want to, it does every think that you want, well almost. the transmitted sound quality is not all that flash, it was intended to transmit to my stereo about four metres away, my stereo must be very fussy on the signal it likes, keeps cutting in and out, however my clock radio that is at the other end of the house, has no problems picking up the signal, my car stereo does even better I can still hear music playing from my computer as I drive down the road, yet my stereo four metres away just won't have it.
There are better quality FM stereo transmitter IC available, I wouldn't recommend the one I tried using.
If I was going to have another go at making one of these stereo transmitters, I would go for a good quality kit.
You may have better luck than I did, but from my experience it isn't an easy thing to do. -
Sorry zgnoh, it's unlikely I will be able to help you any further.
Of course you can ask for help :), someone else knowledgeable in this area will surely help you 8). -
Ante, I misunderstood what you meant, my DMM had a flat battery so I had to use my backup, FTM finger touch Meter ;D, unfortunately it doesn't work any more its not broken, It just refuses to do any more testing ;D ;D.
Thanks again for the advice Ante, I'll get started on this project today and post pic soon :),
Oh yes and thanks to Alun and Ldanielrosa :D.
Has anyone else considered making their own foundry?
You can make it to a very small-scale, and it really isn't all that difficult to do.
Think of all the project boxes you can make, as well as heat sinks,
You can make a project boxe or a heat sink, to the exact size you want, and you will save $$$$$$$$$.
If enough members express their interest in such a project, I will consider putting together all the information needed to set up your own foundry, from start to finish and make it as detailed as I can.
Of course this will be after I successfully set up my own foundry, I also do have commercial foundry experience behind me, this isn't rocket science it really isn't very difficult at all 8). -
Hi zgnoh,
I found this (http://www.engin.umich.edu/group/ctm/PID/PID.html#introduction) hope it helps :). -
Member was requesting information on how a particular circuit worked, best suited under electronics chit chat. [iurl]http://www.electronics-lab.com/forum/index.php?board=21;action=display;threadid=2549[/iurl]
Ante, so it's a bad idea, I think this is what you are trying to say ;D ;D ;D ;D ;D.
Well would you believe I forgot that I had salvage two of these(BTA40-400A) 40A 400V ::), it's casing is isolated and I can easily mount it off board, more than adequate to handle the current and I only need to make one light dimmer switch :D, or maybe I should be calling it furnace temperature control .
I am assuming that it will take more power to drive this TRIAC then the one I am using now ???.
Can you tell me what the DIAC does, AC to dc to drive the gate of the TRIAC?
If it's going to take more current to drive this TRIAC can I use two DIACS in parallel, or just used two to be sure.
I'm having a hard time trying to work out the datasheets, for these two components, I can be a little thick at times :-[. -
Hi Alun,
Funny you should mention that ;D, the TRIAC wasn't insulated from the heat sink with my first test run.
I thought it over before I touched it to see how hot it was getting, and came to the conclusion that it should be LIVE :o.
Being an adventurous kind of guy, I touched it quickly with the back of my hand, I knew I would get a tingle, for some reason I just couldn't resist ;D.
That just wasn't very smart was it ;D. -
Thanks Ante :), I probably wouldn't of taken on a mains power project like this, if I didn't have somewhere someone to ask advice :).
About the cooling fan(DC 12V 0.13A), is there a way I can use it without a transformer, reduce the voltage down enough to use a bridge Rectifier and voltage regulator ??? -
No worries Ante, I have pretty much got those capacitors sorted out now ;). I decided it would be a good idea to place this project inside a insulated box for testing and safety, considering my lack of experience and I was playing with 240V ;D, but it turned out so well I was hoping I could fit the right size heat sink in their, and use it for curing the refractory of the furnace. I started with a very small heat sink and tested it on my fan 75W 240V to get an idea on how much heat the TRIAC will need to dissipate, then I tried the largest heat sink I had, and that's about the biggest I can fit in their, I don't think it would be very practical to try to modify the box to fit a bigger heat sink, after all it was only really meant to be used for testing and getting an idea of the size heat sink I would need. No change of plans I'm still going for 2160W for each element, I'm working my way up to it, just using a little trial and error to see what this project can handle :). Yes I change the fuse to a 10A, the TRIAC is a 600V 15A BT139-600.
I think I will just have to bite the bullet, and scrap the case and start over :(, I have an old computer power supply box that should be just the right size to accommodate two of these light dimmer switch. I didn't use it in the first place because it wasn't insulated.
The heater that I have, has three settings 750W, 1250W, and 2000W, the higher settings is pretty close to what this circuit needs to handle, so it is good for testing, I will need to allow some headroom for the element as they will draw more current when they are cold.
Ante can you offer me any safety advice on the construction?
This is how I am going to go about it. Use a computer power supply case, two separate light dimmer circuit with their own heat sinks, two mains power wall socket's mounted side-by-side on the box for the controlled output supply, one mains power supply lead to supply power to both circuits, a transformer and cooling fan. The in going and outgoing earth wires connected to the metal case.
Thanks for the help Ante I really appreciate it :). -
Ok I'm nearly done with the electronic side of things. I have almost got it right, the only real problem I have had so far is choosing the right size heat sink. I gave it a test run connected to an electric heater, with the heater set at 750W and the light dimmer set to maximum, I could hold my fingers on the heat sink for about five seconds, when I reduce the power a little with the light dimmer switch, the temperature of the heat sink reduced accordingly.
At around 1400W, I could hold my fingers on the heat sink for about two seconds, I think this is its limits.
So if I double the heat sink size I should be right, which is a shame because I think I've made a nice neat little unit, and I could of given the furnace a test run with a single element to see how it went, before adding a second element and making a second light dimmer and putting them into a single unit.
I left out the choke and C1, as they are for reducing radiofrequency interference, because I wouldn't have a problem with that, although I was worried about leaving C1 out in case it served another purpose as well.
I don't know how much heat is normal, for a TRIAC with this circuit and the application I am using it for, does this seem like its working the way it should? Is this amount of heat normal for a TRIAC? -
MP, I can see how it must annoy you and others, it doesn't bother me but you are right.
I think (read this before you post) is a good idea. -
I just thought of something else to add, if you use two probes at the bottom of whatever it is you drop in the water. The water will act as a switch, a conductor linking the two probes electrically triggering the start of the event, and the Hall affects sensor indicating the end.
Yes, good thinking Ante I'll do that. I have a couple of questions, as usual ;D.
In the components list for the capacitors, it says to use dipped polyester, are these Green caps ??? metallised polyester. In the pic they are blue, I have a heap of recycled Green caps some of which are brown, I am assuming they are from different manufacturers, or do the different colours indicate different voltages, I'm having a real problem with reusing these capacitors, how do you tell what voltage they are? -
I also got one of those little radios for free, after purchasing a certain amount at a newsagents, my daughters schoolbooks.
I didn't realise it at the time, but they were actually giving me a little plastic case, with a few useful components inside ;D, that little plastic case is going to make a great little remote-control Jammer, the perfect disguise it will still look just like a radio 8). -
Attached are datasheet for components mentioned above, and PDF file containing information about the 220V_240V LIGHT DIMMER.
Thanks again for any help. -
Hi Ante, Ldanielrose,
Thanks for your reply :),
Ldanielrose, I have experience casting with oil based sand and die casting, large floodgates and irrigation valves, I'm going to give Green sand ago to start with. I'm going to use a steel crucible. I won't be using any flux unfortunately.
I would really appreciate some help, modifying this circuit that I found to suit my application, with the limited choice of components I have available. The only (DIAC) I have available to me locally is (BR100-03) and for the TRIAC (BT139-600 400V 15A) can I use two of these TRIACS in parallel? When playing with mains power I am very reluctant to use trial and error.
Any advice is very much appreciated, Thank you. -
Hi Ante,
Oh well, I at least try to help ;D -
Your need this (http://www.electronics2000.co.uk) it's free and very good, don't let it make you lazy like it does for me.
Hi Yevgeni P.
Thanks for the advice, but I have been checking that box since June 2004 ;) ;D ;D, and it has been working until now :-\.
Making an electric furnace.
in Mechanical constructions/Hardware
Posted
Hi Ante,
It's pretty much as you described ;), the picture below shows three of the four ingredients for the refractory, top left is the perlite, below that is the silica sand and the third is Portland cement, the fourth ingredient to be added after these three are mixed and moistened, is fireclay or bentonite.
The pic on the right shows two spiralling formers, which will create the cavity for the heating elements, with insulating tape joining the two to help create a taper, that will allow the heat from the elements to escape into the main cavity more freely. The spiral formers are glued to the main former body, the tape at the ends of the formers are to hold the ends down until the glue has taken.
Top left shows three drinking straws passing through the outer shell penetrating into the spiral formers, at the point where the heating elements will be connected with machine screws passing through to the outside. There are steel rods inside the straws to prevent them from moving and deforming under the wait of the refractory.
It hasn't all gone without any glitches :(, I'm pretty sure I got a few air pockets in the refractory, which is bad news for when I fire it up, it's likely that it will shatter :o. I fully expected to run into these sorts of problems, it's a learning experience with some trial and error ;), and the expense of making a mistake is very little 8).
