well i'm not accually tranmitting data, there isn't another chip receiving this data. i simply need to spit out say 64Kbit as a bit stream at a particular clock speed. i'm trying to work this in on a pic as i have one in place already, but the solution does not seem easy on a pic..... by bitwise i mean......think of the process need to do what i'm talking about in a pic there is no "put bit 7 from the byte at 0x7h to pin RB3" instruction because pic's deal in bytes, not bits, as their primary block or data. to do that with a pic you have to move the byte containing the bit you want to a reg, mask/compare it then output the result. in psudo C: pin RB3 = (byte & 0b00000010) == 0b00000010; that compiles to almost 10 instructions. of course to output each bit in the byte you have to right rotate the mask or the byte, maintain counters to decide when to load the next byte, etc, and keep everything timed to the output freq is correct. obviously i'm trying to shoehorn something into a pic it wasn't really designed to do...i'm now looking at possibly some memory chips that are capable of just dumping bits and tapping into that but i'm always open to other ideas. thanks for the response -xian
