First of all, you have to figure out where to get a regular signal output from your clock in syncronize with the time. Then start from there designing your circuit to make use of the output signal. e.g. an electrical contact output that you can connect, a notch on the gear set that you can add a micro switch to pick up the signal from motion.... all depends on your intelligence and genius. ;)
