2,433 -
Days Won
1
Everything posted by Hero999
Here's a similar project giving an example of how to do this: http://www.enide.net/webcms/index.php?page=lm3914-batmon
Please post a schematic.
Help with using transistor as both N.O & N.C Relays
Hero999 replied to a topic in Electronic Projects Design/Ideas
The NC function generally needs a permanently live powersupply but there are ways round it. The simplest way is to is to use a depletion mode power MOSFET or a JUGFET driving a BJT being driven by a small pulse transformer. Another trick involves using a small battery to bias a transistor on and use an opto-coupler to turn it off. -
You need to attach the image. Click additional options, then choose, find the file containg the image and click on open.
That's probably not such a good idea. It's a fairly low cost part and if you're unlucky enough to find a bad one in an old piece of equipment, you could waste a lot of time fault finding. It's really best practise to use new and known good parts for a prototype.
You're right, it's a pair of diodes. It's actually quite common to get high power diodes in this kind of configuration. They're commonly used to connect two batteries together or as as a full wave rectifier with a centre tapped transformer in a switched mode power supply. Have you tried typing the part number into a search engine?
The clue lies in the symbol at the bottom of the package.
http://www.electronics-tutorials.ws/logic/logic_6.html http://www.ustudy.in/node/3036
Why not buy one? The LM317 is a cheap commonly available part. If you see one in an old piece of electronics then use it, but it may not be as reliable as a new one. You should always opt for new parts whenever possible.
The current is not the proble, it's the voltage. You just need a 12VDC power supply capable of supplying more than 380mA, 500mA or 1A would do. I wouldn't recommend going over a couple of amps unless you add a fuse but that's only in case it develops a fault. You could use a 12V 100A PSU if you wanted but you'd need to fit a 1A fuse to protect the wiring.
555 calculation in astable mode
Hero999 replied to eplanet's topic in Electronic Projects Design/Ideas
The LED should be wired from pin 3 to 0V in order to have a duty cycle of greater than 50%. -
To answer the origional question. It's definitely better to use a potential divider and a 5V reference. If more current is required, a non-inverting buffer could be used to reduce he output impedance.
It's impossible to say without any additional information such as a schematic or detailed description of the circuit.
How to change 5DCV into +/- 5DCV
Hero999 replied to steveUK's topic in Electronic Projects Design/Ideas
How muchpower do you require? It's possible with the ICL7660 but it's restricted to low currents. http://datasheetoo.com/power-supply/generating-negative-supply-using-the-icl7660-circuit-schematic-and-datasheet.html -
http://uk.farnell.com/cypress-semiconductor/cy3277/programmable-lv-powerline-communication/dp/1828765?CMP=KNC-GUK-FUK-GEN-KWL-G30-CYPRESS_SEMICONDUCTOR
my transistor gets hot, line follower/dark sensor
Hero999 replied to leonheard's topic in Projects Q/A
Posting a schematic would make it easier for us to help you. You obviously need to use a more powerful transistor and/or add a heat sink to keep it cool. Another option could be replacing the Darlington pair with a MOSFET or connect the collector of one of the driver transistor to +V, via a current limiting resistor. -
Why not use the LM317 and put the the voltage selector switch on the potential divider? A Google image search returns a similar circuit to what you need on the third hit. It's easy to modify it to give the voltages you need. You'll need a higher voltage transformer than 12V to reliably get 12V out: 15 V should do. http://www.eleccircuit.com/lm317-linear-power-supply-regulator-selector-15v3v45v5v6v9v-15a/ https://www.google.co.uk/search?client=opera&q=LM317+regulator&oe=utf-8&channel=suggest&um=1&ie=UTF-8&hl=en&tbm=isch&source=og&sa=N&tab=wi&ei=mngKUeTCBcqp0AWVwIDoDw&biw=1920&bih=927&sei=u3gKUeaYGou10QWLs4D4Dg
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000545.pdf
LED stands for light emitting diode and is not a bulb but a semiconductor chip which produces light when an electric current is passed through it. The voltage across the diode is dependant what the chip is made of and the current flowing through it. You need to limit the current which can be done using a resistor or a circuit such as a the Joule Thief discussed earlier. A white LED has a forward voltage of between 3.2V and 3.8V and an AA cell provides between 1V and 1.6V so a boost converter is required: the joule theif does this too.
You're wrong, whether the resistor is in series with both the capacitor and battery or just the battery will make little difference to the charging time.
The resistor is in series with the batteries. A capacitor is not necessary because the battery doesn't care about the ripple current. I agree, increase the resistor to 1k to 2k to limit the current to something more sensible.
ignition device for a miners lamp
Hero999 replied to andyh's topic in Mechanical constructions/Hardware
Yes but the battery would need to be larger to get the same battery life because it would need to store more energy to make up for what s lost in the converter. 25Ah sounds much larger than necessary. Have you simply tried connecting three AA NiMH cells in series to give 3.6V to 4.5V? If that doesn't work, try using C cells and make sure they're real 4000mAh or 4500mAh cells, not just normall AA cells with extra padding. -
The battery voltage is not the problem. The main issue is the charge current is too high.
