2,433 -
Days Won
1
Posts posted by Hero999
Please post a link to the software you're having difficulty with.
If you want to attach a file, please upload it here, rather than over there.
Don't worry too much about viruses, audioguru. Opening a zip file is a fairly low risk activity, far safer than installing software or even viewing a Word document. Even if it does contain a virus which isn't detected by your security software, it's unlikely to run unless you tell it to, i.e. you open the zip file and load an .exe file stored within the .zip.
I'll do the following myself, when I have the time:- Download the .zip
- Check it really does have a .zip extension and isn't executable i.e. it isn't really files.zip.exe
- Scan it with antivirus software.
- Open it with 7-zip.
- Check that none of the files are executable before extracting the files.
- Scan the extracted files with anti-virus software, just in case the scannercouldn't read the zip.
Following those steps will greatly reduce the risk of viruses.
If all is good, I'll attach the file here. -
It's probably too late the original poster but hopefully others will still be reading this.
You can buy USB controlled power saving plugs. Perhaps you could use an MCU to control one via USB.
http://www.savingtrust.dk/public-and-commerce/products/energy-saving-equipment/autopoweroff-plug-banks/autopoweroff-computer -
It's actually reServe energy, because normally when you "tab" on a light switch, you would see the light illuminate for as long as you "poke" (press for 1 sec, and you'll see 1 sec of light). But I need it to flash for 4 secs with just 1 sec of poking the switch.
Oh I misread it.
What mean I mean is why do you need to store energy?
The 12V battery is still there right? All that needs to be done is not switch the light directly. The light could be connected via the control system (microcontroller and transistor/relays) which is permanently connected to the battery. The control system would then be programmed to respond to the switch's status. -
Forgive me for butting in, I've not had time to read the entire thread.
I notice there are lots of LEDs connected in parallel; why? It's more efficient to connect them as three strings of five or even five of three.
If all this does is buffer the PWM signal then why use an op-amp IC? A comparator such as the LM311 or LM393 would be a far better option. -
What do you mean by reverse energy?
It can be done with a simple microcontroller, which is basically a very simple computer on a single chip, that can be programmed to do a variety of different tasks. There are other ways of doing it with logic gates, transistors and relays but by the time you've done that, you might as well have invested the time and money in learning about microcontrollers. -
They're not surface mount LEDs but through hole and the sopts you're talking about are the semiconductor LED dies themselves.
How much current do the LEDs draw?
You could build a tiny PCB with resistors and SMT LEDs but the trouble is building a nice convenient package for it. -
http://www.rapidonline.com/Tools-Equipment/Peak-Atlas-DCA-Semiconductor-component-analyser-36637
I wouldn't recommend tapping into the dryer's electrical system. Although it would be a more complicated project, it's much safer to monitor the sound from the buzzer and trigger a relay.
That circuit is wrong, the transistor is configured as an emitter follower with no gain so there'll be no oscillation. Here's a link to the correct version, with a better explanation:
http://users.silenceisdefeat.net/~lgtngstk/Sites/Circuits/Buzzer/Buzzer.html
It can be made louder by replacing the collector resistor with an inductor:
http://homemadecircuitsandschematics.blogspot.co.uk/2011/12/how-to-make-simple-piezo-buzzer-circuit.html -
The motor will look like three inductors, each with a resistor in series, connected in delta.
You haven't been provided with enough information to answer the question: without knowing the line frequency, it's not possible to solve the problem.
You need to break the loads down into their inductive, reactive and resistive components:
To calculate the resistance of the lighting circuit just use Ohm's law.
You can calculate the capacitor's value using Ohm's law to get the reactance and transposing the formula for the impedance.
The resistance and inductance of the motor can be found by transposing the power factor formula, to get the resistive and reactive components, then transposing the impedance formula to give the inductance.
All of the above requires the line frequency, which is unknown. -
You do not have a transceiver schematic
No I don't.very Important
So what do you want me to do about it?
Do you want someone to design one for you?
How much are you willing to pay?
So far you haven't even given a proper specification, so how do you expect anyone to help you? -
I will read about these level logic mosfets later on but I have a feeling they switch on / off rather than turn on slowly etc...
It's nothing to do with switching speed, a logic level MOSFET has a low threshold voltage so can be switched from 5V or less, a normal MOSFET usually needs 10V. -
Another way would be to derive the current by the number of turns of the coil. Deriving the current by the resistance is not possible you guys say? due to the AC current. I have a spare motherboar with the same coil that i can unsolder. I can use it to measure the characteristics if needed.
But I thought you were talking about DC current?
Deriving the DC current is easy: you need to know the resistance and voltage and use Ohm's law.
Calculating the AC current is also not difficult but you need to know the inductance too.The only option I have is to use a Hall Effect sensor I think, but thats my last solution because i have to place it inside a computer. THere is a great chance that interference will occur.
A Hall effect sensor will work but for AC it'll need to work up to the frequency being measured.
But why do it the hard way? It's DC so measure the resistance of the coil, the voltage across it and calculate the current. -
Hi Guys,
I have a couple of questions but I know you might be busy, I would appreciate ANY answer even for 1 question. :-*
I have a situation where I would like to switch an electric match. The typical trigger power for such a device is 12v 800mA - 1A. I have three questions for this.
1. I was told that Mosfets are better than Transistors for this situation. Why? Is this true?
http://www.google.co.uk/search?client=opera&rls=en-GB&q=MOSFET+BJT+advantages+disadvantages&sourceid=opera&ie=utf-8&oe=utf-8&channel=suggest2. I need to choose a Mosfet which is fast and reliable. I need it to turn on fast but its only going to turn on once in an hour's time, and its only going to be used for a few mS until the match is lit.
Going from your previous posts, you need a logic level MOSFET.3. Lets say I connect 12V DIRECTLY to Drain/Collector, and Ground DIRECTLY to Source/Emitter and when I switch the Gate/Base an 'infinite' amount of current passes to the match however it takes mS to burn and once it burns the current flow is not possible anymore. Would you recommend such a design? I calculated that to put a resistor to limit the current to 1A, it needs to be at least 12W which is huge and expensive. I need to switch around 300 of these... imagine having 300 resistors of 12W each ... :-\ Any other Ideas?
You don't need a 12W resistor, as the power dissipation will only 12W for a few ms, a lower power resistor (try 1W or 2W) will be fine as the power won't be applied for long enough to overheat the resistor.
With no resistor to limit the current, all of the power will be dissipated in the transistor which will have a lower resistance than 12R so will dissipate much more power, possibly enough to overheat it.
There is no point in using an opto-coupler, if both circuits use the same ground.
yes
Photo up.vatandownload.com/images/z1uepcvbhanbxicuwh6.jpg
i need help you
Nice project, assuming you really did build it yourself. -
Robot spies: sounds interesting.
Who are you spying on? -
You need to know both the current and voltage,in order to calculate the resistance, for more information look up Ohm's law.
I want to control Rbatm
Why didn't you say that before?
What's an Rbatm? -
That's odd, it was working before, try this:
http://buenotech.en.made-in-china.com/product/NewJdEgbyjkq/China-6-Channel-Digital-Fiber-Optic-Video-Transceivers.html -
this web saet ero
What do you mean?
Please post in English. -
http://www.huihongfiber.com/6-channel-video-optical-transceiver.html
force limit a motor
in Theory articles
Posted
It's fairly straightforward with a DC motor or AC motor. The motor's impedance reduces (therefore drawing more current) as the mechanical load increases. A current limit could be used to restrict the torque or detect the shaft being jammed.
I don't know about a stepper motor. I think using a DC or AC motor with an encoder, forming a servo system, is the best route to take. It's also possible to measure the back EMF from a DC motor or synchronous AC motor to monitor the speed so an encoder won't be necessary for speed regulation, unless you need to know the exact position of the shaft.
