72 -
About Dido
- Birthday 07/18/1987
Dido's Achievements
AN920, thanks for your comment :) I decided to build the second circuit the one using a crystal oscillator, I have got another question, I think that I will need a frequency counter in order to adjust the trimmer capacitor to the right value, what`s the use of SA in this circuit: I can`t understand the table drawn in the bottom of the picture. What are the two CD4040 for?
Hello, I want to make myself a digital clock using LED displays as readout, I`ve been searching for some schematics of clocks, there are lots of such in the internet, but I still couldn`t find a reliable one. I don`t want to use a microcontroller, I want the clock to be made with CMOS or TTL IC`s. I found a German website where I found lots of digital clock circuits http://pitts-electronics-home.de/electron/schpluhr.htm I want to make the circuit Schaltplan einer 6 stelligen LED Digitaluhr mit CMOS- IC's, I have a few questions about this circuit, as it will use a 555 timer what accuracy should I expect?, Is this circuit going to work?
Dear friends, I have built many times the LED Display Digital Voltmeter project and it works pretty fine. Now I want to build myself a Digital Thermometer using this voltmeter, but I want to use seven segment Vacuum Fluorescent Tubes instead of using LEDs. I have a small problem in constructing the driver for these tubes as they use 30V for the segments to be lit. I am thinking of using PNP switching transistors which will drive the tube`s electrodes. I can`t figure out which will be the best transistor to use for, have you got any ideas? Can you tell me if you have more practical and convinient ideas for the driver? I am attaching you the datashees that I found in the internet, the tubes are russian make, I have got a whole bag of these tubes and I want to make it with these as they are very bright and easily to be read. I hope that there will be someone who can give ideas. Regards: Deyan Dimitrov
Hi, I am planning to build myself an electronic clock with a big and bright LED display. I looked over the net and I found out that the schematic that I have attached is the perfect for me and I just thought that you`ll be interested in it too. The only problem I have is that I can`t find a scanned PCB of that project.It`s DIY kit No 73. I`m a little lazy and I don`t want to spend hours and hours over the PC drawing that PCB, so can anyone tell me where can I find that PCB and download it? You can find more info for that kit at http://shopping.netsuite.com/s.nl/c.317485/sc.8/category.44/it.A/id.445/.f k73.pdf k73sch.pdf
I opened my camera but I haven`t tried propanol I tried blowing on it ant it worked now I haven`t got any problems at all but I am stiill not sure about propanol. I think that it is suitable for heads or other devices but it is not suitable for optics and optical devices. ??? ??? ???
hi prateeksikka are you sure about propanol? have you ever had such a problem? ???
Hi badai, Some printers have such possibilities to print in a mirror mode, this depends on the driver you use and of course the additional program that you have installed with your printer. Myne is Epson C82 and when I print for myself PCB`s I just set it to mirror mode from the preferences menu. 8)
What do you mean with that 20K nanometers?
Hi Ante, Trigger I have opened my camera I even dismounted the lens and when I saw that I`m inexperienced working with optical devices such as object-glass, lens etc.... I pieced it together again. I went to the local service and he told me that he can`t do anything with my camera because he hasn`t got the proper tools. I think that I can do it myself, I`ll try blowing with a pump on it first. I won`t even think to wipe the dust because I`m sure that I`ll scruff it more.
I`ve got a problem with my digital camera and It really freaks me out when I see that the photos are miserable and scruffy. ;D So let me explain you the real problem. A month ago I realised that when I shoot a picture and then I view it on my PC I see two spots on the picture. The first spot (the big one) looks like a very small fine hair, so I thought that there is dirt on the lens I cleaned the lens but this didn`t help then I searched in the net about that and I soon realised that there is dirt on the CCD sensor of the camera. I understood that this is a common problem in new cameras. I found sites which explain how to clean your sensor but I`m not sure that I can do that with home tools. Have you ever had such a problem? Look down at these links maybe you`ll understand better what I mean :o http://www.cleaningdigitalcameras.com/ http://www.pbase.com/copperhill/ccd_cleaning http://www.bythom.com/cleaning.htm
Look at these links they might be useful ! ;D ;D ;D http://www.quatech.com/support/comm-over-isa.php http://www.quatech.com/support/comm-over-mca.php http://www.quatech.com/support/comm-over-pci.php http://www.quatech.com/support/comm-over-cpci.php http://www.quatech.com/support/comm-over-pcmcia.php http://www.quatech.com/support/comm-over-usb.php
1. Visual Basic 2. Quick Basic 3. Borland Pascal
The difference b/w an ISA slot and a PCI slot is that ISA slots are 16 bit and PCI slots are 32 bit. ISA slots are used in old computers thay are long usually black coloured but you should know that ISA slots are no longer manufactured.For more info try to search in google or sth.
