94 -
Posts posted by karthikeid
yes the input voltage at U2 varies from 0 to +11.4V....
then what should i do... -
when the U2 will measure zero... what should i check it is not working...
i have made some mistakes in the pcb and i have corrected it now the led is not glowing and voltage at the current is 1.8, the output of U1 +11.4...
but even i am not able to vary the voltage... :(
at c1 it is 28.6V
hi redwire can u post the pcb u made??? -
hi
here is an datasheet of an ic from ti, can u help me to put a volume controller to this circuit and what is meant by 4step gain control, multiple class d devices, shut down and mute control.... ???
what should be the input voltage and current?
http://focus.ti.com/docs/prod/folders/print/tpa3100d2.html#samples -
the wiper at one end of the pot measures 4.7V and at other end -0.6V input voltage of U3....next hat should i do..
my psu seems to be not working there is no voltage variation and i have used tle2141 opamps....what should i do.... ??? :( the led is glowing without any load....
i have posted the circuit diagram and the pcb made by me... -
hi
what are the things to be checked before connecting the circuit to load...
and i have used only 24volts 3amps transformer what will be the maximum power delivered to the output ??? -
so can i use an 20W amplifier to an 60W 4 ohms speaker.....
hi
i have a doubt that an 20W amplifier can be used to 60W speakers ??? if not post a circuit for 2x60W audio amplifier.... -
thanks for the information provided i am update the complete circuit once i have build it...
hi
can u post me anyone circuit here pls ??? -
hi
can u modify this circuit with an electret mic and all the correction to work well because
i am looking for a smaller size transmitter ???
the previous circuit u gave works fine too...but little big one :( -
hi
any circuit that will transmit voice for 100meters range using fm but the transmitter must be small enough... -
hi
using the fm transmitter module how to transmit and receiver voice..
link for that fm module
http://onlinetps.com/shop/index.php?main_page=product_info&cPath=126_127&products_id=454
pls help me to construct a circuit.... ??? -
hi
how test a condenser mic ??? -
hi
i am talking about the center of the ift is red in colour -
hi
how to find the value of the IFT coil???
i c a red color plastic or an grey color how to identify it ??? -
is there any other substitute to overcome this ??? -
hi
i need a circuit to lit 50 leds in ac voltage 230v,50Hz... -
hi
ok chill hero999...
why i am asking is that i have those components with me so that is why i was asking about that circuit....kindly help me out to do this circuit....
i cant get LM2931A...is there any substitute ??? -
hi
i am not able to upload pictures to the threads..
the info. displayed is
The attachments upload directory is not writable
what to do ???
0-30V Stabilized Power Supply
in Projects Q/A
Posted
the output of U2 reads 28.5V when in input of U2 above 0.5V and output U2 reads zero at input is zero
