94 -
Posts posted by karthikeid
hi
what will be the range atleast 500m... ??? -
hi
can u provide me some other circuit that will have a good range... -
hi
http://rapidshare.com/files/276652026/fm_transmitter.pdf.html
check this circuit need some help building this one... ;D -
hi
in this circuit
http://w1.859.telia.com/~u85920178/tx/bug5.htm
just change 547 which is parallel to 2.7pf, into BF494 then it is working fine -
hi
why dont u do ur own pcb it is very simple process only. for one pcb it will cost very high... -
hi
i have powered it by a 9V battery only... -
hi
i have made this circuit
at one frequency it is working fine for a long distance but when i speak there is bzz noise nd not able to hear clearly, can u help me to overcome this problem ???
in this circuit i have used 10pf instead of 12pf.... -
can u tell me wheather this circuit works out well
http://www.aaroncake.net/circuits/fmtrans.asp -
hi
i need a fm transmitter circuit that works properly, very urgent pls help me. ::) -
hi
using the PIR need a circuit that counts using a display when it detects.
check this for pir
http://en.wikipedia.org/wiki/Passive_infrared_sensor -
hi
for this circuit...
http://www.electronics-lab.com/projects/power/003/index.html -
hi
what happen to the power supply forum topic was it been removed ??? -
hi
simple application that can be implemented with using optocouplers?? -
hi
pls help me with a simple circuit using optocoupler using PC814 or some ???other one -
hi
i am having only 10000uf/63V capacitor can i use it instead of 12000uf ??? -
Fm transmitter
in Projects Q/A
Posted
hi
some of the components are not presently available to me to build that circuit...
but i have attached one more file can u provide me some suggestions on it...
i am not able to attach the file here saying the dir is not writable here...
so i have uploaded in rapidshare sorry for the inconvince.
http://rapidshare.com/files/277282868/transmisso__fm.gif.html
in this circuit 0.3uH is given how to wind the coil ???
