I'm in the process of deciding on a design for a lab power supply, and this one seems to fit the needs that I have. However, I have been reading some of the forum replies and I have a question. Why are you guys using OP amps that aren't rail to rail? If you used a rail to rail amp, it would eliminate the need for the charge pump negative voltage generator and make life a whole lot easier. Am I just missing something, or is there a reason for using non-rail to rail OP amps? Thanks, Dan
