You are spot on with the 100 vs 200 HP, it is amazing to watch the requirements as speed increases. To go 150 MPH in a normal car, you can do it with as little as 200 HP. To go 200 in the same car you need almost 600 HP. There is a VERY steep logarithmic curve in getting from 100 - 400 mph. Aero plays a giant role, but it will only get you so far. As for turning, we run a straight 5 mile long course, no turns during the run. You line the car up at the start line, you have 1 mile to push the vehicle up to speed using a push truck, then up to five miles to get to your max speed. At the end of a run, after you have slowed sufficiently, you make a left turn while coasting to the return lane and wait for your support vehicle to come pick you up. We will not have to worry about differential speeds due to cornering. I was thinking of using two hall effect sensors and just varying the tooth count accordingly as you had stated, seems to be the easiest/best way to go. Where I really need help at is I have never done any PIC design or programming. I have only a fundamental understanding of how it works, that's not going to cut it. I would really like some basic guidance on what is needed to get started and a little nudge in the right direction on a structured approach to accomplishing the goal. High level goals: Collect input from multiple sources (2). Aggregate the input by subtracting non-powered input from powered input sensors. Output difference in sensor input to a gauge, bar graph or series of LED lights. Specific questions: Which PIC is best suited for accomplishing the goals? Which software(s) can you recommend for coding the logic? What equipment is needed to transfer programming logic onto the PIC? Will I need to design other items into the circut prior to or after the PIC? (Basically, do I need to breadboard a PIC and the sensors with resistors, capacitors or other elec equipment or can I just directly connect two sensors and an LED bar graph to the PIC? If you can't tell by my question, I have no idea how to design the circut...) Is there an electrical circuts for dummies book or some reference material that you can recommend? I'm not afraid to do some research and reading, however, I'm not looking to earn a doctorate in electrical engineering either. If I am going to be spending 6 weeks reading how to do it, I'd just as leave pay someone to do it for me. However, where is the challenge and fun of having someone do it for me? Thanks for you postings, I appreciate the help.
