Fight
47 -
Everything posted by Fight
Attatch diagram first circuit is use for current limiting transiter is use for current increasing transistor current provide 5A at all voltage range 1.2-30V this circuit is good better best or not
ok my mean that if using transistor current increasing method for lm317 or lm338 regulator ic than this method ok or not because volatge vary from 1.2 to 30 v 7805 or 7812 is fixed regulator
what is the efficiency of these circuit if this method using with lm317 and lm338 than thses ic better current and voltage or not
please explain it using examples if 10R resistor use than
if i change the value of 1R instead of 0.1R than what change in circuit current the resistor wattage the voltage across R = ? the current across R = ?
Attatch diagram what is the role of emittr resistance 0.1 ohm why using this resistor
I Attatch Diagram if i use digital pot by replacing R2 that ok or not and if digital pot using in variable power supply by changing voltage and current than ok or not please send digital pot ic nos that available in market
solid state relay can hadle high voltage and current any other method using SCR and other method control as switch
if i use cd4066 1. this ic Open or close the resistor like other sitches (mean short and maximum current flowing) 2. if short than max current handle 3. if short than max Voltage handle = 15V or greater if i use 5V supply for ic than switch 15V can handle or not
i try to buy a digital pot but not meet digital pot NO DS1803 AD7376 if meet the digital pot in market than this lower position only 64 position digital pot
Because digital pot is not available in this country
i trying a fixed resistor to variable resistor using no of fixed resistor and control using switches these resistor 1,2,4,8,16 in steps mean using fixed resistor control digital mode
i design a smps power supply 0-30V any body help me with diagram and other information
if own design a saimple solid state relay please send any diagram
Thats good answer
Very Very Thanks Hero
Hello to all i attatch diagram the resistor short or open thru switches these switches can handle thru relay i want these switch are electronic switches how control thru BJT or other switching device
In lm338 data sheet asking Features: Guaranteed 7A peak output current Guaranteed 5A output current But problem is that in Electrical Characteristics: Vin-Vout = 30V Than max current 1A what is meaning that lets Vin = 38V and Vout = 8V 38-8 = 30 and Vin-Vout = 10V or less than 5A can handle mean 38-28 = 10 mean 8 to 28V 1A handle and 28 to above 5A handle Attatch Diagram 2. in Application Hints diagram all diagram is designed that can handle 5A Attatch Diagram
