foxOnTheRun
5 -
Everything posted by foxOnTheRun
Hi, my pc power supply broke yesterday, so instead of trashing it, I opened it to salvage some components. I found this small board inside: The psu has and input connection and an aux port to power up the monitor. This small board was fitted so that it received mains power from the left (from the main cable), then the output (right side) was connected to the main psu circuit board by a couple of wires and soldered to the monitor socket. This should be the circuit, the "out" label is going to the monitor and the psu board. Value for the resistor and cap are correct, no clues for the inductors value, as far as I could observe, there were no values written. So, what's its purpose? passive PFC? how could I see something interesting from LTspice simulation? Tnx!
2AA Batteries and one supercap cell
foxOnTheRun replied to foxOnTheRun's topic in Electronic Projects Design/Ideas
All right, why is simple, I want to build a small demo board for a school project and I wanted to investigate in such kind f control - I found barely nothing on books. Right! same numbers I got: _ in the first test I can also drop the supercap requirement - my objective is find a control schema to control the currents flowing outside my single elements _ in a second time, I could put the supercap back and programming a little I could play with some nice control schema like, keeping the current from the battery stable/low and draw from the supercap during peaks in power consumption But, before going on telling wonders of supercaps and so on, from where I could start looking for control methods (circuit) for such currents ? II was thinking of playing with the resistor output network found in many switching regulator, if I can cheat em and force their output voltage to change.. but I think it's not much feasible the way they tell you in datasheet to not parallelize multiple unit.. (traco, densei-lambda). Any suggestion? tnx :) -
Hi to all, let's start simple: what should I do if I wanted to play with a couple of AA batteries 1,5v and 1 or 2 supercap cell (2.7v each) to power up a small LED? I'd like to build a small demo board where, given a programmable device to implement some logic (example like a mid range PIC like 16F690, 16F684) I can set the % or the balance of power flowing to the LED from these 2 sources (or a motor if that suit better as example) - I'd like to balance the power absorption from these two reservoir. Example, if I would attach a trimmer to the PIC, I could set the flow like: _ 100% from battery _ 20% from battery, 80% from supercap _ 100% from supercap .. and so on As sidenote, I can stabilize the working DC level to 5v it via a simple switching circuit like max756, so 2AA and 1 supercap cell would be stepped up to 5v independently (or down, depending on power sources voltage, or even a SEPIC..but..). But then I'm missing the building step to implement the power flow control :( I feel I really miss some building blocks in electronics, one in particular being the capability to actually ""control"" power flows (double brackets necessary..). I've posted this simple example, not to be solved by some cheap tricks (diodes, limiting resistors, relays..), rather to really get the point: how do you treat paraller power sources? adding more, at which level do you stabilize, regulate and control power sources? I was thinking of having just one switching regulator, then I could feed it with the supercap cell and 2AA.. but the problem is still the same, I've only shifted the place where to balance the flow of power.. what's the keypoint? Hope I explained the problem clearly, have you got any ideas? Tnx.
