Scott S
Members
  • Posts
    23
  • Joined
  • Last visited
Scott S's Achievements
Newbie
  1. Would it be possible to use one pot for the whole thing ? It would be easier to make each color the same brightness that way. Also, would this peak detector work: http://freecircuitdiagram.com/2008/09/07/single-transistor-half-wave-peak-detector-circuit/ Would it be possible to also have 1 peak detector for the whoe thing ? Thanks for your help
  2. would I put the pot before the first capacitor ?
  3. nevermind, I figured it out, but it is somewhat "blurry". would a peak detector help this ? Can you reccomend a peak detecting circuit ? Where would I attach it ? Also I notice that as I turn the volume up, the leds get brighter. Is there a way to adjust this so that it would be as bright at listening volume as they are on max volume ? I plan using a splitter and listening while it blinks. Thanks for your help
  4. I can't get it working. I'm trying the left channel with only one led, trying to start small. Everything seems to be connected correctly. I'll list the components I'm using, maybe one isn't correct. 35v 10uf cap, 2n3904 npn, a 22 ohm resistor, 150 ohm resistor, and a IN4003 diode. Is there any common noob mistakes that I may be making ? Thank you for your time.
  5. I have a noob question. How does the transistor control the leds, when the leds are connected to the battery and the transistor is connected to the leds ? sorry for the noob question.
  6. Did I correctly fix the circuit ? Thanks for your help
  7. The voltage is at 6 volts, and the main resistors are 22 ohms. The two capacitors arer also 10 uf, like you suggested. So, the olnly thing I have to change is the resistors in front of the leds ? Also do I have the ground connected correctly ? I wasn't sure if that was where it went or not. Thanks for your time.
  8. Is the circuit now correct. Thanks
  9. Wouldn't the 7.5 volt circuit last just as long as a 6 volt one ? The 7.5v draws 200mA, the 6v draws 400mA. 7.5v: 200mA drawn until 6v would last roughly 4 hours. 6v: 400mA drawn until 3v would also last roughly 4 hours. I'm not trying to start an arguement, just trying to point that out.
  10. sorry i was looking at two differnt post and replied to the wrong one. once again, sorry. :-[
  11. Wouldn't the 7.5 volt circuit last just as long as a 6 volt one ? The 7.5v draws 200mA, the 6v draws 400mA. 7.5v: 200mA drawn until 6v would last roughly 4 hours. 6v: 400mA drawn until 3v would also last roughly 4 hours. I'm not trying to start an arguement, just trying to point that out.
  12. I have attached an updated circuit. Is everything correct in the schematic ? Is there anything i can do to the circuit to have the leds blink at listening volume as they would blairing, as I would like to attach a splitter so I can listen to headphones while it blinks ? I found a few "simple" peak detector circuits. If I decide to use one, would I put it before the capacitor ? I would use 2 of them, correct ? Would the results of the peak detector be worth installing it ? Also, would either the 2N3904 or the 2N4401 transistors work ? Thank you for your time, I really appreciate it.
  13. Thank you for pointing that out audioguru. I have attached the schematic. Can you explain how I can alter my circuit to include the peak detector circuit ? Thanks
  14. I found 2 transistors that are similar to the BC548 in your schematic, the 2N3904 and 2N4401. The only difference between the two, that I could find, is the collector current. The collector current of the 2N3904 is 200mA, while the collector current of the 2N4401 is 600mA. Would it be better to have a higher or lower collector current ? Another noob question: What is the importance of capicators ? Here is a schematic I made. http://www.flickr.com/photos/[email protected]/4769178237/ Is this correct, or is there something i forgot to do ? Thanks for helping
  15. Am I going to have to use 2 transistors since there's gonna be 20 led's in the circuit ?
