I got a bag full of ne555 and the cmos version too (is not the texas instruments version but some cheap china stuff) and i want to use a it with a infrared led and a "infrared sensor" (it got 2 pins, i guess is a fototransistor that operates in ir domain) and i will make a reflective sensor, when you move the hand abou it the ir light will reflect back to the sensor and it will trigger the toggle. Fore better range i pulse the led at around 38khz with a 555 (lucky i found a nice application that makes all the math for me and gives me directly the resistor and capacitor values i need for the timing the i asked). The CD4013 is ideeal for this but it got a major drawback, if i pover him at 12v it will need a trigger voltage of 12v too. There i will need to use a transistor or a op-amp. The transistor whud be easy, but i need 1 that whud accept a lower voltage at base and is capable of conducting 12v from C to E, any ideea on a common transistor that can do this ? PS The project is intended to run from a 12 power supply and act as a switch for 220v application. Thanks for your help.
