4 -
clemsontiger's Achievements
5 Watt Audio Amplifier
clemsontiger replied to clemsontiger's topic in Electronic Projects Design/Ideas
Thanks for the help. I dont HAVE to use opamps. But I must simulate the circuit to show a frequency response of 20Hz-18KHz, and a power delivered of 5W to an 8 Ohm load. And I knew that using transistors would be extremely difficult to do. So in my proposal, I decided I would use opamps/ic's. To simulate this program all I have is PSPICE which doesnt half work and Im not real proficient with it either. Does anyone have any ideas as to how to go through with the simulation? -
You make a good point, I have to use a 12 volt power supply. Its in the specifications for my design. I apologize for the confusion. -
Im a student and I need to design an amplifier using an opamp, and I dont know what opamp to use. I have to deliver a 5 Watt output to an 8 Ohm load also with a flat electrical response of 20Hz - 18KHz. What IC should I use? LM383? 741? And Im not even sure how to start designing one of these as far as a circuit goes. Should I just start with a basic inverting configuration? Or non-inverting configuration? Is there a better configuration to use? Should I have to consider heat sink issues?
