40 -
Everything posted by johndeverill
7 segment pressure gauge help? Modify voltmeter from Projects?
johndeverill replied to johndeverill's topic in Projects Q/A
Hi MP, I've taken a look and I can see it could display the voltage for me fine. The issue I have is that I want to display 0-30 instead of 0-100mV so that it displays the pressure. Can you point me in the right direction so that I can do the conversion? Many Thanks John -
Many thanks. Ill take a look, John -
Hi, Relating to my other post. I have a pressure transducer that outputs 0-100mV for 0-30psi. What I would like to do is create a 7 segment led (well double/triple) figure type that would display 0-30 for 0-100mV being supplied. If anyone could point me in the right direction on this one that would be great. Even if you just know a good site that would be fantastic. Many thanks John
Hi Ante, Many thanks for your help. What I want the circuit to do is upon, say, 14psi being applied to the pressure transducer (46.7mV by my calculation) I want to adjust a potentiometer to vary when the transistor allows 12v to flow to the solenoid and hold it open (it is normally closed). This would be the primary circuit. A secondary circuit would also be there, same as the first, but also with some sort of astable 555 circuit that would be activated (much in the same way as the first, I thought, with a pot/transistor) and then it would be possible to vary the Hz between say 1 and 50Hz which would then cause the solenoid to beopening and closing upto 50 times a second. I have read elsewhere that it may not actually fluctuate at high Hz but just partially open but this is fine aswell. I have also read that it may be necessary to put a relay in line to protect the transistor. Hopefully this makes a bit more sense of what I am doing and I do apologise for my ignorance but I am only just learning about electronics. Thanks John
Hi, I wonder if anyone can give any advice on a circuit I want to build. I have a pressure transducer that output 0-100mV for 0-30psi. I have a solenoid that is activated by 12v. I want to control at which pressure the solenoid is activated. The circuit I imagined would be the transducer sending a signal to a potentiometer and then to a transistor, which would let the 12v through to the solenoid. I thought that if I sourced a transistor that activated at 1mV the pot could be used to vary the pressure. Does this make sense? Also I want to put a stage in before the solenoid that would be an astable 555 circuit so that I could pulse the solenoid. Does anyone know of any example of 12v astable 555 circuits that I could use as a guide. Many thanks in advance and hopefully someone can help!!
