Im curreltly building a slot machine. and i need a embedded audio board to create the sound. > The board will talk to my main slot machine controller using i2c or 1 wire or what ever. > It needs to have ONE mono output (i can connect to a simple amp) > It needs to have 2 internal channels you it can play 2 samples at the same time. > Needs to read the samples from either a SD card or USB, i dont mind / dont mind what format. > needs to have 2 busy flags, so i know when the samples are complete I cant seam to find a device that can play 2 samples at once there are loads of embedded audio modules that play 1 at a time but not 2 :( Any ideas of the best way to achieve this? Thanks
