4 -
freakn3d's Achievements
Ldanielrosa - I hadn't considered using a LED...that's an interesting thought. I'm not familar with the differences between the LEDs as you reffer to them. However I will say that a LED is not as likely to be used since I already have the zeiners in stock. ;) Trigger - Humm....sudden up voltage as in suddently being dumped with 12v or static type of voltages? I would also prefer to use an optocoupler but had ZERO sucess in setting up a test circuit (using a 4N30). Have you sucessfully used optocouplers your self?
Where to buy electronics parts?
freakn3d replied to xelon's topic in Electronic Projects Design/Ideas
I'd try: mouser.com Digikey.com newark.com if you know WHO makes the parts you are looking for then go direct to the mfr and find their distributor, sometimes they'll have a search function that'll find the part in their distribution network. RHD -
Howdy all. I have a working project that has two circuits on sepearte boards, there is a cable between the two that provides power and signal from the parent circuit to the daughter circuit (signal is one way, not bi-directional). A small micropocessor is sending out a 1k-10kHz variable frequency from the parent circuit to the daughter circuit with 1.7 v pulses. Problem: occasionally over voltage (two other occasions it was 12v one occasion was that or static) goes up the signal wire and fries the output on the processor. This is bad! (not to mention expensive!) I have thought of adding a 2.4v (lowest i could find) Zeiner/Resistor combo to the parent circuit to prevent feeding too much voltage to the processor. Alternately I could use an optocoupler to completely isolate this cable from the processor (i have bread boarded a couple of 4N30 circuits and testing has NOT been sucessful. What do you think?
