hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
Here is the first Datasheet. HCC_HCF_4046B.pdf
Make the cdw,mp3 to work off speakers
hotwaterwizard replied to TakeAbyte's topic in Electronics chit chat
Does your TV have Audio output RCA Jacks in the back? Does your Player? If so all you need is a Stereo or Amplifier with input Jacks. The TV has a limited amount of audio so you need an extra Amplifier to hook more speakers up. I am an Audio Tech as well as a Pressure Washer Tech. Believe me, any other way you will burn out the amplifier in the TV and you won't have any sound at all! -
Is this it? C10 = ECG113A = DS-17 = DS-131 This Diode has 3 pins and resembles a transistor G10 = 1N4007 = 1 amp Diode DO15 Case Plastic Looks like a standard Diode ECG113A.pdf
Here is all I could find so far. R34B16B General-Purpose Silicon Rectifier Manufacture IR 11 Available http://www.cmbcomponents.com/
T7900 and T7778A datasheets?
hotwaterwizard replied to AVRFreakMan's topic in Datasheet/Parts requests
Check out page 26 on this one! http://earthlcd.com/zlcd/downloads/lm24014w.pdf -
Is this the Machine you are working on? Here is more info. Frac-100. Made by Pharmacia, Uppsala, Sweden Parts http://www.sci-bay.com/partspages/lkb_parts-1.html http://www.sci-bay.com/partspages/lkb_parts-2.html Authorized Repair Center http://www.sci-bay.com/index.html Frac-100.pdf
Here is more info. http://www.optrex.com/pdfs/Dmf5000_11-20.pdf http://www.eio.com/lcdprodt.htm http://www.microcalinc.com/ http://www.ic-distributors.com/HTML_ICD_T-2.shtml lcd_display.txt -
Found More Info. Radioshack 1400 Laptop Parts list http://support.radioshack.com/support_computer/doc30/30549.htm To order parts call 1-800-843-7422 or visit your local RadioShack store. Reference # Cat.No. Description NP Part # TLX-XD1-8 10878577 IC,T7778A LCD CONT MX1625 10878577 100P FLAT PAK MX1625 TLX-YD1-3 10878585 IC,T7900 LCD CONT MX1626 10878585 92P FLAT PAK MX1626 http://support.radioshack.com/support_computer/doc30/30547.htm[ -
here is one for sale on ebay. http://www.summitcellularcenter.com/SAD1024-BUCKET-BRIGADE-DELAY-IC-NEW-RETICON,i3714117096,c41415.html Or you can Buy one here! http://www.smallbearelec.com/Ordering/Stocklist.htm
This will help you for sure! http://www.geofex.com/sad1024.htm http://www.du.edu/~etuttle/electron/elect39.htm Datasheet Attached. SAD512-1024.pdf
Here is my Idea for a DC to DC Converter with no Magnetics. 12vdc to +-15vdc Will it work?
It appears to be a Mono IC chip. Sometimes TA and KIA are interchangable. I am not giving up on it until I get all of the info or until I get to this Link. http://www.datamath.net/
Do you know the manufacture of the Kit? Maybe the Kit #
Looking for to buy a schottky diode
hotwaterwizard replied to pdmtr's topic in Datasheet/Parts requests
BAT29 Schottky Diode Equivelent 1N5390 SGS Thompson Purchase http://www.danssmallpartsandkits.net/ Datasheet http://www.xinsemi.com/english/up/upload/BAT29.pdf BAT29.pdf -
Here is something but I don't know what it is. http://www.technochips.co.jp/freeprog/sanyo_lc78636/lc78636.zip
I'm having a real hard time with these! Here is what I have so far. These only mention your chips but, it is something. http://www.eio.com/lcd.htm http://earthlcd.com/zlcd/downloads/lm24014w.pdf http://forum.microchip.com/tm.asp?m=29114 http://www.mpja.com/download/14619opap.pdf -
I assume it is out of a car stereo. The number reads like a Toshiba Chip. What brand of stereo is it out of and model #
Let's try something else What is it in and what is the make and model. Let's try to find you a schematic diagram and see what it tells us.
Power supply for AMP in CAR
hotwaterwizard replied to nanopoylos's topic in Electronic Projects Design/Ideas
My whole Idea is to use 2N3055 Transistors. I don't like MOSFET. Anything that can blow from touching it with your finger is not relyable in my book. MOSFET is static sensitive and I don't like the Idea of using something them in a powersupply with magnetic fields and stray electrical currents floating around. -
datasheet for PCF 5073 (philips)
hotwaterwizard replied to quattro's topic in Datasheet/Parts requests
I recieved the hard copy. It was coppied from a book. I scanned all of the pages then I doctored them up and found a way to convert them to PDF format then I found another way to put all of the files into one PDF file. Here it is! Pcf5073.pdf -
I'm Getting Close!
Desperately needs info for this chip..
hotwaterwizard replied to a topic in Datasheet/Parts requests
Here it is! CS16312EN=UPD16312 Brand SEMIC CS16312EN Dynamic VFD Driver. Package Type QFP44 Vacuum Fluorescent Display (VFD) Controller/Driver IC UPD16312.pdf -
Here are some Ideas! Motorcycle Alarm http://www.zen22142.zen.co.uk/Circuits/Alarm/motorcycle.htm Proximity Alarm http://www.geocities.com/IECMaster/circuits_alarm/cir_alarm005.html Touch Activated Alarm http://www.uoguelph.ca/~antoon/circ/alarm2.htm
More Info would be nice. What is the operating voltage? Is it a Bicycle Moped or Motorcycle? How much space do you have? Simple or complicated Design? Code alarm or Key alarm? Motion Sensor, Vibration Sensor, Touch Sensor? Tell me what you have in mind.
Try these links. http://www.uoguelph.ca/~antoon/gadgets/555/555.html http://home.cogeco.ca/~rpaisley4/LM555.html
