LIST P=PIC16F84 PORTA EQU 05H PORTB EQU 06H COUNTER EQU 37 Hibyte EQU 020 Lobyte EQU 021 Count EQU 26 Tents EQU 022 Thous EQU 023 Hunds EQU 024 Tens EQU 025 Ones EQU 028 d1 EQU 019 d2 EQU 018 d3 EQU 017 Timer1 EQU 29 TimerX EQU 2A Point EQU 2B ; Program table pointer Select EQU 2C ; Copy of RS bit OutCod EQU 2D ; Temp store for output code RS EQU 1 ; Register select output bit E EQU 2 ; Display enable NUM_HIGH EQU 30H NUM_LOW EQU 31H X1 EQU 32 X2 EQU 33 X3 EQU 34 ORG 100H GOTO START ORG 0H START MOVLW B'00000001' TRIS PORTA MOVLW B'00000000' TRIS PORTB CALL InitLCD CALL Out_LCD0 CLRF PORTB LOOP BTFSS PORTA,0 GOTO START CALL Out_LCD1 CALL DELAY BTFSS PORTA,0 GOTO START CALL Out_LCD2 CALL DELAY BTFSS PORTA,0 GOTO START CALL Out_LCD3 CALL DELAY GOTO LOOP RETURN DELAY ;30minutes delay movlw 0xB6 movwf d1 movlw 0x64 movwf d2 movlw 0x20 movwf d3 Delay30min_0 decfsz d1, f goto $+2 decfsz d2, f goto $+2 decfsz d3, f goto Delay30min_0 nop return ;----------------------------------------------------------------------------------------------------------- Out_LCD1: BSF Select,RS ; Set display data mode MOVLW 'R' ; Time period CALL send ; Display it MOVLW 'M' ; Space CALL send ; Display it MOVLW ' ' ; Equals CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it ; Show fixed characters---------------------------------------------------------------------------- MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; micro CALL send ; Display it MOVLW '3' ; secs CALL send ; Display it MOVLW '.' ; Space CALL send ; Display it MOVLW '0' ; Space CALL send ; Display it MOVLW '0' ; Space CALL send ; Display it ; Home cursor----------------------------------------------------------------------------------------- BCF Select,RS ; Set display command mode MOVLW 0x80 ; Code to home cursor CALL send ; Do it RETURN ; done ;------------------------------------------------------------------ Out_LCD2 BSF Select,RS ; Set display data mode MOVLW 'R' ; Time period CALL send ; Display it MOVLW 'M' ; Space CALL send ; Display it MOVLW ' ' ; Equals CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it ; Show fixed characters---------------------------------------------------------------------------- MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; micro CALL send ; Display it MOVLW '3' ; secs CALL send ; Display it MOVLW '.' ; Space CALL send ; Display it MOVLW '1' ; Space CALL send ; Display it MOVLW '0' ; Space CALL send ; Display it ; Home cursor---------------------------------------------------------------------------------------- BCF Select,RS ; Set display command mode MOVLW 0x80 ; Code to home cursor CALL send ; Do it RETURN ; done ;------------------------------------------------------------------ Out_LCD3 BSF Select,RS ; Set display data mode MOVLW 'R' ; Time period CALL send ; Display it MOVLW 'M' ; Space CALL send ; Display it MOVLW ' ' ; Equals CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it ; Show fixed characters---------------------------------------------------------------------------- MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; micro CALL send ; Display it MOVLW '3' ; secs CALL send ; Display it MOVLW '.' ; Space CALL send ; Display it MOVLW '2' ; Space CALL send ; Display it MOVLW '0' ; Space CALL send ; Display it ; Home cursor---------------------------------------------------------------------------------------- BCF Select,RS ; Set display command mode MOVLW 0x80 ; Code to home cursor CALL send ; Do it RETURN ; done Out_LCD0 BSF Select,RS ; Set display data mode MOVLW 'W' ; Time period CALL send ; Display it MOVLW 'E' ; Space CALL send ; Display it MOVLW 'L' ; Equals CALL send ; Display it MOVLW 'C' ; Space CALL send ; Display it MOVLW 'O' ; Space CALL send ; Display it MOVLW 'M' ; Space CALL send ; Display it ; Show fixed characters---------------------------------------------------------------------------- MOVLW 'E' ; Space CALL send ; Display it MOVLW ' ' ; micro CALL send ; Display it MOVLW ' ' ; secs CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it MOVLW ' ' ; Space CALL send ; Display it ; Home cursor---------------------------------------------------------------------------------------- BCF Select,RS ; Set display command mode MOVLW 0x80 ; Code to home cursor CALL send ; Do it RETURN ; done ; MAIN LOOP----------------------------------------------------------------------------------------- send MOVWF OutCod ; Store output code ANDLW 0FF ; Clear low nybble MOVWF PORTB ; Output high nybble BTFSC Select,RS ; Test RS bit BSF PORTB,RS ; and set for data CALL PulseE ; and clock display CALL Onems ; wait 1ms for display SWAPF OutCod ; Swap low/high nybbles MOVF OutCod,W ; Retrieve output code ANDLW 0FF ; Clear low nybble MOVWF PORTB ; Output low nybble BTFSC Select,RS ; Test RS bit BSF PORTB,RS ; and set for data CALL PulseE ; and clock display CALL Onems ; wait 1ms for display RETURN ; SUBROUTINES------------------------------------------------------------------------------------ ; 1ms delay with 1us cycle time (1000 cycles)------------------- Onems MOVLW D'249' ; Count for 1ms delay MOVWF Timer1 ; Load count Loop1 NOP ; Pad for 4 cycle loop DECFSZ Timer1 ; Count GOTO Loop1 ; until Z RETURN ; and finish ; Delay Xms, X received in W ----------------------------------- Xms MOVWF TimerX ; Count for X ms LoopX CALL Onems ; Delay 1ms DECFSZ TimerX ; Repeat X times GOTO LoopX ; until Z RETURN ; and finish ; Generate data/command clock siganl E ------------------------- PulseE BSF PORTB,E ; Set E high CALL Onems ; Delay 1ms BCF PORTB,E ; Reset E low CALL Onems ; Delay 1ms RETURN ; Initialize the display ------------------------------------------------------------------------------- InitLCD MOVLW D'100' ; Load count 100ms delay CALL Xms ; and wait for display MOVLW 0F0 ; Mask for select code MOVWF Select ; High nybble not masked MOVLW 0x30 ; Load initial nibble MOVWF PORTB ; and output it to display CALL PulseE ; Latch initial code MOVLW D'5' ; Set delay 5ms CALL Xms ; and wait CALL PulseE ; Latch initial code again CALL Onems ; Wait 1ms CALL PulseE ; Latch initial code again BCF PORTB, 4 ; Set 4-bit mode CALL PulseE ; Latch it MOVLW 0x28 ; Set 4-bit mode, 2 lines CALL send ; and send code MOVLW 0x08 ; Switch off display CALL send ; and send code MOVLW 0x01 ; Clear display CALL send ; and send code MOVLW 0x06 ; Enable cursor auto inc CALL send ; and send code MOVLW 0x80 ; Zero display address CALL send ; and send code MOVLW 0x0C ; Turn on display CALL send ; and send code RETURN ; Done END
